Difference in stall speed related to stress?
STR so you multiply torque more. Direct increase
in input shaft torque. Further, you are guaranteed
to be up on torque peak (vs the stocker which will
hold you down to well less; the 3000 and 4400 are
both liable to be near peak torque).
A 3000 is often seen about 2.0 - 2.2 STR while a
4400 is likely to be 2.7 or more. The stocker is like
1.8 or so.
I would expect there to be maybe 20-25% higher
input shaft torque applied, 4400 vs 3000. Relative
to stock you will put 2X the torque to the box,
between being up on the torque flat-top and the
higher torque multiplication (STR).
