Tranny hp tuners step in need help
Old Mar 27, 2007 | 10:25 AM
8a8mfh's Avatar
Seems to work fine for me. Heres the download box after you click through a maze of links.
Old Mar 28, 2007 | 08:34 PM
dnkynrbk's Avatar
so anyone have any ideas
Old Mar 29, 2007 | 12:54 AM
CrazyChris's Avatar
Attachments are still not working. Here is a link to a .ZIP file with both the tune and log files. Just click download off this page: http://www.4shared.com/file/13112778.../DNKYNRBK.html
Most of the tranny settings have been set back to stock just trying to get this figured out.
Old Mar 29, 2007 | 10:03 AM
dnkynrbk's Avatar
post back to the top....
Old Mar 29, 2007 | 03:40 PM
dnkynrbk's Avatar
can any hp tunner read this and help out
Old Mar 29, 2007 | 06:07 PM
8a8mfh's Avatar
I can read it but it doesn't look like it'll cause the problems you're having.
Old Mar 29, 2007 | 11:02 PM
dnkynrbk's Avatar
what do you think it is
Old Mar 29, 2007 | 11:40 PM
8a8mfh's Avatar
Somethings wrong under the speedometer table. Not sure if thats the problem, but it's not right.
Old Mar 30, 2007 | 01:00 AM
CrazyChris's Avatar
A 25" tall tire / 3.23 rear gear = the 7.73 ratio. He is running a taller tire now but that shouldn't affect the shifting based on the mph values in the tranny tables. What is incorrect? Thanks!
Old Mar 30, 2007 | 03:17 PM
TRU-2GM's Avatar
get a th400 money bags...
Old Mar 31, 2007 | 06:16 PM
dnkynrbk's Avatar
back to the top
Old Mar 31, 2007 | 10:20 PM
  #32
DrkPhx's Avatar
Originally Posted by cablebandit
its another setting i bet...vengeance had a car do this...i THINK it was the p0121 setting under engine diagnostics. PM ron @ vengeance racing
It's under Engine Diagnostic>TPS>Parameters. Raise the TPS Test Min and Max MAP values.
Old Mar 31, 2007 | 11:32 PM
  #33
senicalj4579's Avatar
Sorry to but in guys but I have the p0121 code also. I got this after installing an ls6 intake. Also my traction control off light stays on and is disabled. I hear that the p0121 code will disable the traction control. Any one know if that is true? Also if I get a tune and raise the TPS test min and max MAP values will my problem go away? Any feedback would be great.
Old Apr 1, 2007 | 09:30 AM
  #34
dnkynrbk's Avatar
So you think that is it?
Old Apr 1, 2007 | 06:33 PM
  #35
DrkPhx's Avatar
The LS6 intake is a straight bolt in and should not set this code. Double check the connector and MAP sensor on the back of the intake. In your case, I think changing the values is a band aid fix and may make the code go away, but not neccessarily fix the problem.
Old Apr 1, 2007 | 06:38 PM
  #36
DrkPhx's Avatar
Give it a shot.
Old Apr 2, 2007 | 07:06 PM
  #37
dnkynrbk's Avatar
hey will try what you said and see what happens
Old Apr 3, 2007 | 11:30 AM
  #38
If it was the map sensor wouldnt there be a code for the map sensor? Do you think it could be the map or the wiring? Why would messing with the values be just a band aid? Manual says this code is set when the predicted throtle angle does not match the actual throtle angle. It does make some kind of sense that putting a bigger intake on the car could trigger the code because it is bringing in more air. Not sayin your wrong,just wondering why it would be just a band aid in my case.
Old Apr 4, 2007 | 10:09 AM
  #39
dnkynrbk's Avatar
to the top still havent found the answer.
Old Jun 12, 2007 | 08:35 AM
  #40
RICEETER's Avatar
sorry to bring this up from the dead, but did you ever find your answer?
did you raise those values? what did you raise them to? did it work? are those values the same on EFIlive?
