reverse input shaft and a spring set
Old Mar 18, 2007 | 01:17 AM
TKhawk01's Avatar
Default reverse input shaft and a spring set
Do I need to replace my reverse input drum. And should I try to straighten out this spring set or get a new one, I used a press on it and didnt have a large enough seat on the spring.
Thanks
Attached Thumbnails reverse input shaft and a spring set-p3170367web.jpg   reverse input shaft and a spring set-p3170369web.jpg   reverse input shaft and a spring set-p3170371web.jpg   reverse input shaft and a spring set-p3170376web.jpg
Old Mar 18, 2007 | 02:34 AM
performabuilt's Avatar
LS1Tech Sponsor
drum is ok for a stock of high performance band but not a wide band . wear is relativley even,, But spring cage should be replaced a bit warped it appears
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Mar 18, 2007 | 06:20 AM
FLT's Avatar
FLT
I would check that reverse input drum with a straight edge. If you can see day light in the center of it, throw it away. The spring cage was from the low and reverse correct? I would definitely replace it. I have plenty of cages laying around and have new drums in stock if you need one. I replace a lot of parts in my rebuilds so I keep a pretty good inventory. If you need something let us know. Vince
