4L60 Removal/Install
E-clips can be tough also, I used a little 90* pick tool that worked pretty good, it workes great for taking various electrical connections you'll run into on the project also. There is a damn good install link I used ,but I can't remember what it was
I look to see if I still have to saved..... It's been used by several people here, so if I can' find it do a search and i'm shure it will turn up.
I look to see if I still have to saved..... It's been used by several people here, so if I can' find it do a search and i'm shure it will turn up.if you do find that link could ya pm it to me?
Thats good to know! I have a lift and plenty of extensions and swivels. Thanks!
I also used this link that was posted above:http://modernmusclecars.net/forums/a...p?do=tcinstall
Good luck, it's not that bad...
the converter bolts will be a bitch, i ended up cutting through one of the feet of the stock converter with a sawzall just to get the converter loose...
