Company Claims to be the best
They talk about how they have the strongest servos, and the 8 full tickness clutches are better than 9 thin clutches. There is also more information on thier website that basically stats that other companies are using the wrong stuff.
What do you guys think of Performance Automotive?
Ski
P.S. be careful posting links to NON-sponsers.
Bring a pile of stuff to a local builder you might give him something he's never seen before and yours will be the first one he's set up. Not a good situation. And if it fails they will almost always blame your parts selection being at fault.
If you go with a local builder ask how they're going to build it and what they're going to use, see what they say.
It would be better to buy from a sponsor here IMO.
As for just getting the parts and having a local shop throw them in there again I would beware, Each manufacturer uses the componets we do because we have learned what works with what and just throwing a bunch of the best parts in there and hoping for the best generally is not a good idea.
I was basically scammed, and the guy I bought it from was scammed and he didn't even know it. So long story short, I will have it built by Proformance, (he's local) and let them do it their way.
If the quote you got from the local shop is significantly less then IMO it isn't being built to the same specs or standards as Performabuilt, FLP, RPM etc.
I went local the first time rebuilt at $1000 + $350 for the install. I drove the car for 7K and now 3 and 4 is out with little if any racing - not more then 6 passes on a h/c 347 only putting out 385 rwhp - all city or highway miles. I suspect all I got was a new clutch pack and a shift kit for the $1 k.
Get it done by a company and sponsor here that makes a living at rebuilding 4l60e's specifically.
You will save money in the long run.
BOSS APPROVED!
