Dynamic braking went out the window
Old Apr 3, 2007 | 09:08 PM
jay_99z's Avatar
Do you have an aftermarket converter?
Old Apr 3, 2007 | 09:17 PM
performabuilt's Avatar
LS1Tech Sponsor
You are very welcome .
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Apr 4, 2007 | 04:10 PM
Fratsit's Avatar
No..he is still running a stocker. I have told him that an after market converter would be a good first mod.
R/
Frat
Old Apr 5, 2007 | 01:17 AM
LS1Tech Sponsor
Personally I would do and aftermarket converter and trans then go from there and put worrys as you build behind you.
__________________
Call 888-744-6542
Old Apr 5, 2007 | 04:22 PM
Fratsit's Avatar
When he is ready I know he will be calling you. I need to turn up the heat on him to get some go fast goodies on that hotrod. A solid trans and converter is a great place to start.
R/
Frat
Old Apr 5, 2007 | 09:23 PM
jay_99z's Avatar
R/
Frat
Cool. The reason I was aking was I've seen some cars (mine included) get a shift solenoid code with high stall converter. Goes into limp mode and all. I used to get it about once a month. Had previously swapped out solenoids. So....turned off code and haven't had an issue.
Old Apr 7, 2007 | 05:12 AM
Fratsit's Avatar
Hey Thanks.... thats some good info to know and I'll keep that in my back pocket.
R/
Frat
