tranny / converter problem
Old Sep 25, 2002 | 10:55 AM
Billy C's Avatar
Default tranny / converter problem
Ive got a 99Z A4 with a SY3500 converter , The car is getting a bad Chatter/vibration when the tourqe converter trys to lock and when it does lock it has a strange vibration that comes and goes about every 5 seconds ... It seems to be getting worse , Is it in my conveter or tranny ? I thought only the ST line of yank converter had problems ??????
Old Sep 25, 2002 | 01:13 PM
Billy C's Avatar
Default Re: tranny / converter problem
Thanks ragtop !
1.)No codes
2.)very light throttle is where I notice it the most , mainly when the conveter is trying to lock
3.)it comes and goes once conveter is locked...
4.)my car has Ed wright tuning , mac headers , lid , thats about it , It does have 3.42s it used to be a M6 car ...
5.) tranny has about 30,000 miles conveter about 5,000 miles !
Thanks for your help ! BTW , The car shifts great , no slugish shifts !
Old Sep 25, 2002 | 06:20 PM
Billy C's Avatar
ttt
Old Sep 26, 2002 | 12:51 AM
Ragtop 99's Avatar
could be the converter clutch or could be tranny issues.
1) any ses or pending trouble codes?
2) does it happen under very little throttle or just under heavier load?
3) does it go away at any speed?
4) what other mods and tuning have you done?
5) how many miles on the converter, on the tranny and when did you last change the filter & fluid?
Old Sep 26, 2002 | 08:12 AM
Ragtop 99's Avatar
probably the clutch is glazing a bit if it occurs at only very light throttle and goes away once locked and rpms increase.
If your LTRIMS are off, you'll need EW to fix that and ask him to bump your lock-up speed a 2-4 mph so it locks where the presure is a bit higher. Likewise if EW cranked your tranny pressure way up and warped the clutch plate, Yank may not fix it.
If your Ltrims are fine and tranny pressure is normal or slightly raised, call Yank and ask them about it.
Old Sep 26, 2002 | 02:57 PM
Ragtop 99's Avatar
Buy a new stick and change the filter too. The converter will likely retain most of its fluid.
Lube guard is worth a shot, but the problem will come back in 5k - 10k miles if there are any tuning issues, so do a quick ATAP check.
Old Sep 26, 2002 | 10:03 PM
Billy C's Avatar
cool , how many quarts does the tranny take with a full converter ?????
Old Sep 27, 2002 | 12:43 AM
Billy C's Avatar
Thanks again man , I am going to change the fluid this weekend again and see what happens , I broke my tranny dipstick so how many quarts of fluid to I need to put back in ? The tourqe converter stays full when you change fluid right ?
Old Sep 27, 2002 | 12:54 AM
topfig1's Avatar
Go to AAMCO or NAPA and pick up a pint of Lubeguard for tranny's. Put it in and drive normally. took me e week to clear up the chatter.
Good luck.
Fig
Old Sep 27, 2002 | 08:11 PM
Billy C's Avatar
???? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Sep 27, 2002 | 08:15 PM
Orange Krush's Avatar
Try this ! <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
http://www.gm.com/automotive/gmpower.../4l60_main.htm
Old Sep 27, 2002 | 09:51 PM
Billy C's Avatar
Thanks for the link !!!!! <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Oct 14, 2002 | 04:25 PM
U r welcome ! <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Oct 14, 2002 | 07:30 PM
gwj's Avatar
gwj
From: Live Oak, FL - in the woods where the creatures lurk.
Front wheels on Rhino ramps, pull pan, change filter, 5 qts dead even every (3) time (stock pan).
