Keep the Vig3200 or go put in the PYE 3800
Old Sep 25, 2002 | 09:41 PM
NX†C's Avatar
Default Keep the Vig3200 or go put in the PYE 3800
it will be a nitrous car with a built trans and either of the 2 converters. heres what i know now:
vig3200- a great nitrous verter having a flash stall of ~3800 yet has a lower STR of 2.0. cuts very good 60' for full weight cars on nittos or et streets. it uses precision's #6 pump. it works better on the gas than its big brother the vig3600 which has a flash of ~4300, and runs the good risk of over revving getting up in the rpms that quick.anything else worth commenting about?
PYE3800 - a new product from yank designed for a power adder such as nitrous. will have a flash stall of ~3500 on motor and only achieve ~3800 on the gas. has the higher STR of 2.7. havent heard about what its consistantly 60'ing but my guess is 1.7 unless you can top that with premium traction.
i have the opportunity to use either one as the PYE300 is on the way from a trade, but have the vig3200 sitting up at the shop. the only reason i took it out is because i broke all three of the bolts connecting the verter to the flexplate doing a 80 to 120 punch and now it needs to go back to precision for external repair (welding, bolt extraction, helix coiling). just really curious as to which one would work best in conjunction with s2 heads/cam, built 4L60E and moser 12bolt using 3.73s. i appreciate any insight you have and information perceived.
<small>[ September 25, 2002, 09:44 PM: Message edited by: X']['C WS6 ]</small>
Old Sep 25, 2002 | 10:45 PM
nysbadmk8's Avatar
Default Re: Keep the Vig3200 or go put in the PYE 3800
i dunno man... my vig3600 stalls all the way to 6200 under a 100 shot... i also have heads & cam
im swaping for a yank PTE 4000-4200
Old Sep 26, 2002 | 08:03 AM
Ragtop 99's Avatar
How much are you spraying?
Old Sep 26, 2002 | 09:40 AM
NX†C's Avatar
a 100-150
Old Sep 26, 2002 | 09:54 AM
Ragtop 99's Avatar
If you are running good with the vig, keep it. 100 shot should be fine, and 150 will probably be ok too.
Old Sep 27, 2002 | 12:01 AM
Patrick G's Avatar
LS1 Tech Administrator
I agree with Ragtop. A 100 shot is not much. A 150 starts to get you leaning toward a more nitrous-built converter. 175 shot and up demands a converter with more holding capacity (like the larger Pro Yank converters).
I only run a 125 shot, so my Pro Thruster works just fine.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
