How does a torque converter work?
Old Apr 6, 2007 | 11:20 PM
02SS:ZEUS's Avatar
Default How does a torque converter work?
Is there a faq somewhere that explains how a torque converter works? Or can some please give me the low down? I'm coming over from a T-56 and am new to racing with an auto trans. I have a Rossler RMVB T-brake TH400 with an ATI 8" 4000 stall converter, cooler, and B&M Pro Ratchet shift kit going in the car.
Can someone give me the basics?
- The difference between an 8" and 10" converter.
- What is meant by the converter "flashing?"
- A good rpm to leave at off the T-brake?
- Anything else that I should know???
Old Apr 7, 2007 | 08:32 AM
smoknta's Avatar
Go to any of the well know names and they have explainations of there websites:
Try fuddle, edge, yank, any of these should be of hellp.
Old Apr 7, 2007 | 09:35 AM
MY02REDWS6TA's Avatar
Here is a basic description of how torque converters work..........
http://auto.howstuffworks.com/torque-converter.htm
Old Apr 7, 2007 | 12:50 PM
Tainted's Avatar
it jsut does
Old Apr 7, 2007 | 12:53 PM
daniel6718's Avatar
hows the posi-trac on a plymouth work? it just does!
Old Apr 7, 2007 | 12:55 PM
Tainted's Avatar
there it is I couldnt remember it exactly but I fixed it now
Old Apr 8, 2007 | 08:26 AM
Ragtop 99's Avatar
For a Tbrake, the idea is leave at your stall speed, assuming you bought a stall matched to your motor.
8" converter is much easier to make into an efficent converter at high stall speeds.
Old Apr 8, 2007 | 01:19 PM
02SS:ZEUS's Avatar
The converter is matched to my motor. ATI won't let you pick what stall you want. They ask you everything about your car, from the cam and intake size, to the header and collector size...and rear tire size, gears, etc. Then they tell you what stall the canverter is going to be. They told me that mine would be right around 3800-4000.
So off the t-brake, I should leave right around 4000rpms?
I'm still confused about what people are talking about when they say "flashing" the converter.
Old Apr 8, 2007 | 01:35 PM
Tainted's Avatar
zeus I notice yur in fayettenam... would you ever like to meet up sometime, mmaybe go on a cruise around town or out by the fort bragg reservation?
Old Apr 8, 2007 | 03:16 PM
02SS:ZEUS's Avatar
Yeah man, I'd be down for something like that when I get back. I'm deployed right now, I shoud be back mid-May. And as soon as I get back the car is going to the shop for a trans swap. But I'll definately be getting some track time in when I get the car back. Stay in touch man.
Old Apr 8, 2007 | 04:44 PM
IWantAnA6's Avatar
Basically? It allows the engine to idle while the car is standing still, in gear (Which would be very bad to try to do with a manual car.) The torque converter does exacly what it's name suggests: It converts engine torque as it pass through to the tranny to ratio of 100% on the engine side to almost nothing (Stand-still, no throttle) from 100% to almost 100% (WOT, moving)
Thats all I got. For things like diameter, stall ratings and other some such you'll have to search the intraweb. It's useful for more than cheap ****. I promise!
Old Apr 8, 2007 | 04:55 PM
Ragtop 99's Avatar
Yes, leave at 4000.
Flashing the converter is when you stomp the gas from a dead stop. The converter will flash up close to its rated stall speed.
Old Apr 8, 2007 | 05:29 PM
chiefs camaro's Avatar
what converter should i put in my six speed camaro? im thinking a 3200 stall... it needs one bad
Old Apr 8, 2007 | 05:34 PM
Summit2345's Avatar
calie0's Avatar
what a newbie.. you should sell that car and buy a honda...
Old Apr 8, 2007 | 05:51 PM
IWantAnA6's Avatar
now now people... For all we know he could be the first camaro 6l80 e swap, connected to a viper v10 no doubt. You know those v10s need the high stalls...
Old Apr 8, 2007 | 06:44 PM
02SS:ZEUS's Avatar
Originally Posted by Ragtop 99
Yes, leave at 4000.
So is this good, or bad? Should I floor it from idle and flash the converter when I leave the line, or should I use the T-brake and leave at 4k?
Old Apr 8, 2007 | 08:23 PM
Tainted's Avatar
you have a pm zeus
Old Apr 8, 2007 | 08:27 PM
bene's Avatar
Trunion King
the fluxcapacitor converter. I heard it's the best converter for your 6 speed.
Old Apr 8, 2007 | 11:27 PM
FASTERthanYOU's Avatar
Thats only if u spool the flux to 13.75psi and use all your nos's at the same time.
