Input drum and shaft?
Old Apr 15, 2007 | 07:13 PM
Kiss_My_99SS's Avatar
Default Input drum and shaft?
I have a 99 camaro 4L60e trans. What year and model input drum and shaft will work ? Like a 2005 4L60e input drum and shaft from a truck?
Old Apr 15, 2007 | 08:31 PM
FLT's Avatar
FLT
You can use any drum that is 98 and later. You do need to make sure that it is a 300MM style. I can get you a drum and swap the shaft for you if you would like. Send us an email or give us a call if you would like to go this route. Vince
Old Apr 16, 2007 | 10:45 AM
How do you tell if it's a 300mm style?
Old Apr 16, 2007 | 04:24 PM
PBA's Avatar
PBA
It does not have the torque converter clutch seal at the tip of the shaft. The seal will sit just behind the teeth. It will have 30 splines, and measure around .990" OD.
