converter install
Old May 29, 2007 | 12:32 PM
Bryan @ Speed Inc.'s Avatar
Default converter install
i've bolted up the trans to the motor... right now i just sinched up all the bolts, can i bolt up the converter to the flexplate like that?
or do i need to pull the trans away from the block a bit....?
thanks for the help.
Old May 29, 2007 | 01:46 PM
performabuilt's Avatar
LS1Tech Sponsor
Do not pull the trans away from the engine you may unindex the pump and break it, What is sinched?But yes the converter should turn freely if all is well and you can put the bolts in , Be sue to pull the converter forward then put bolts in do not use the bolts to pull the converter forward
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old May 29, 2007 | 03:21 PM
thanks for the response.... synched/snugged - just ran the bolts in all the way.there is no room between the bellhousing and the block. that's the way i should have it to bolt up the converter right?
Old May 29, 2007 | 03:35 PM
LS1Tech Sponsor
Thats correct , It also should have been easy to turn the converter to alighn the bolts .
__________________
Call 888-744-6542
Old May 29, 2007 | 03:49 PM
yea i haven't even gotten that far yet... i just didn't want the trans hanging on the bolts, so i ran them all the way in and tightened them until i can get another chance to work on the car.
Old May 29, 2007 | 03:51 PM
LS1Tech Sponsor
Ok just holler if you need any additional information and good luck with your install
__________________
Call 888-744-6542
Old May 29, 2007 | 03:55 PM
thanks a lot man!
