TH350 Overhaul & Shift Kit
Old Jun 1, 2007 | 02:51 PM
bluecamaroz28's Avatar
Default TH350 Overhaul & Shift Kit
What is a good overhaul kit and shift kit for TH350 transmission.
Old Jun 1, 2007 | 04:18 PM
WE TODD DID's Avatar
Depends on what you want.
Old Jun 1, 2007 | 05:16 PM
smoknta's Avatar
Transgo makes a good shift kit.
Old Jun 2, 2007 | 09:56 AM
Would like to rebuild the transmission for race use.
Thinking of B&M master overhaul kit and transgo shift kit(manual). Do I have a better choice?
What other internal parts that I should replace to make a stout TH350?
Old Jun 2, 2007 | 10:01 AM
performabuilt's Avatar
LS1Tech Sponsor
I would get a hardened race for the intermediate sprag. You could also upgrade the low sprag but since your going full manual I dont know thats its nessesary since you will have the low clutch on anytime your in first gear which will support it very well. The intermediate sprag race is the only real weak link in the setup your building they are known to shatter on the 1-2 shift.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Jun 2, 2007 | 02:16 PM
Trying to decide on overhaul kit/shift kit between:
BMM-21042 Automatic Transmission Rebuild Kit, Master Racing, GM, TH350, Kit
TRG-350-S Shift Kit, Stick Type, GM, TH350
or
BMM-30229 "B&M Transkits Automatic Transmission Rebuild Kit, TransKit, GM, TH350 Kit", includes auto/manual shift kit
or
HUP-HP3288K "Hughes Performance Transmission Rebuild Kits
Automatic Transmission Rebuild Kit, Premium Race with Kolene, GM, TH350, Kit"
Another choice for shift kit is:
BMM-30228 "B&M Transpak Kits
Shift Kit, Transpak, GM, TH350/ TH375B/ M38, Each"
Anyone have used any of these? Prices put aside.
Old Jun 2, 2007 | 02:25 PM
LS1Tech Sponsor
I have allways used transgo sorry ,
__________________
Call 888-744-6542
Old Jun 2, 2007 | 07:18 PM
smoknta's Avatar
I am putting a Transgo Shift kit in mine. With a hardened race, kevlar band, and a new pump.
Old Jun 2, 2007 | 07:42 PM
LS1Tech Sponsor
You know the intersting thing about that band is the only time it actually has any affect is when your in second manually and giving no throttle, Its and intermediate overun band it makes the slowing affect on the manual down shift from 3-2 at 0 throttle.
__________________
Call 888-744-6542
Old Jun 3, 2007 | 04:37 AM
What do u think of increasing the number of clutches and decreasing the number of steel plates? Is it possible?
Would that increase the life and strength of the clutches?
I am not a transmission guy but trying to understand things.
Old Jun 3, 2007 | 12:43 PM
FLT's Avatar
FLT
Every clutch plate needs to be accompanied by a steel plate. With the way you are talking about doing it you will be decreasing the holding power of the clutch pack.
Old Jun 3, 2007 | 02:29 PM
Vince,
I've this transmission guy claiming to build a bullet proof TH350 with this method and just a B&M transpak. Should I trust the work? I think some valve body modification, too.
If only 1st & 2nd are used, is it possible to decrease the clutches of 3rd gear and increase 1st&2nd clutched and how is that going to affect 1st&2nd. Why would the holding power decrease?
Old Jun 3, 2007 | 04:12 PM
FLT's Avatar
FLT
Each clutch pack is in a different location. You would not want to remove clutches from the high reverse drum (3rd gear). There would not be a benefit because by doing this it will not allow you to install more in the intermediate or forward clutch pack. I think that you might be confused on the info that your builder is telling you. I personally do not use B&M shift kits so I not sure about your builders knowledge.
