Tips on installing my PI stall converter?
Old Jun 9, 2007 | 03:34 PM
spec_j's Avatar
Default Tips on installing my PI stall converter?
do i need to add any shims to it?? or anything to get it perfect?
Old Jun 9, 2007 | 03:55 PM
Predator T/A's Avatar
just make sure its in the pump all the way should fall in three times and then the flywheel will pull it to where i needs to be......make sure to fill it
Old Jun 9, 2007 | 04:29 PM
calongo_SS's Avatar
My PI converter was very tight. I had to stand the trans up on end to get it to go on the pump.
Old Jun 9, 2007 | 11:18 PM
spec_j's Avatar
i read that it was a really tight fit, so this is the reason im asking, better ot ask then mess something up
Old Jun 9, 2007 | 11:24 PM
performabuilt's Avatar
LS1Tech Sponsor
Just make sure get the converter indexed to the pump if you can get fingers behind your not there well unless you have really skinny fingers
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Jun 10, 2007 | 01:03 AM
spec_j's Avatar
cool. So i take it that i do not need any shims at all to do this install?
Old Jun 10, 2007 | 01:07 AM
no it will fit like it is or the convertor was made wrong
Old Jun 10, 2007 | 06:59 AM
PBA's Avatar
PBA
The torque converter to flex plate clearance should be .080" - .125". To check this, the transmission should be tight against the block, push the TC toward the back of the transmission, check the clearance between the TC and the flex plate mounting hole. You can use a feeler guage till you get some resistance, add the numbers up. Ideal clearance should be what is stated above. If it falls in this range, bolt it up you are fine. If more than this, post???
Old Jun 11, 2007 | 02:40 PM
spec_j's Avatar
ok thanks. reason i asked was a friend with a turbo T-type had to do that with his...
good info i will right this down and check it in hte morning when i install it
