shift kit washers
With the heavy duty band in place it really becomes a preferrence or as needed basis on the washers.
I am concerned that the L/U issue was present prior to this unit. I read that right... right?
Is this unit the one that was in the car previously? If so, yeah replacing the valve mod could repair it. If it is not the same unit I would be concerned that indeed it is a logic issue or a voltage bleed into the L/U electrical control circuit. I am fairly certain that it is possible to inhibit L / U functions entirely, has this strategy been implemented? If it is inhibited across the board and still applies intermittantly, then I would definately consider a thorough harness inspection.
John
