lost third?
I put the selector in 2 and it worked fine. but had very little power in third. reved but had a small small amount of power.
I checked the fluid level and it looked good. But if i hurt something wouldn't i have small pieces of medal shavings on the tranny dip stick? the fluid was clean and had no shavings on it at all.
it started happening again. I'm guessing the clutches are wearing down a lot and some time it catches and other times it doesn't? it seems if i get it to a "perfect" rpm and then put it in D it catches some times and will shift into third and fourth....
but im going to pull the tranny later in the week and bring it to my trans guy.
I got my car back from outlaw performance back in march i believe; and it turns out....(please reassure me they weren't trying to **** me over)
-they "couldn't" hook up my trans temp guage
-they put the wrong dipstick in (6" too long!!!!)
-and it was about 4qts low on fluid.
i just found all this out.
yeah figured this all out when i went to pull the tranny and no fluid came out when i loosened all the bolts.
but anyways we got the right dipstick and filled it up correctly. its leaking a little because of the gasket. but at light throttle it revves in third with a little power when i give it a lot of gas. (but not full power) and the second i let off and give it gas it will shift.
and higher throttle % it shifts with out missing a beat. I did 3 WOT runs and every one was amazing. Better then i have had in months (because of 4qts low I'm sure)
my thoughts.
-vacuum regulator on the outside of the trans.
-solenoid controlling line pressure.
-the damage has been done and pull the tranny
what do you guys think?
i just found all this out."
Thats not an update, it's more information that helps a whole bunch when trying to help diagnose problems long distance and on a keyboard!!!
I don't understand how they could have gotten the "wrong dispstick", is this a 4L60E we are talking about or was there a conversion to a A3?
And yeah while driving an automatic transmission around 4 quarts low is not the best thing, it doesn't always mean it's burnt up. What did the guys at Outlaw say? is there a warranty on the unit?
and I'm not even going to call them. they looked for any excuse they could to make me pay for THEIR mistake when the motor spun TWO bearings the second time.
