troubleshoot this problem for me please!
Old Jul 13, 2007 | 08:43 PM
bene's Avatar
Trunion King
Default troubleshoot this problem for me please!
I don't know what is up w/ my car, it was fine then suddenly this problem showed up. The car seems to slip bad around town in a stop and go traffic. On the highway, it didn't want to lock up or kick it into overdrive. I got it locked to 45 MPH and it didn't even do that. The Z28 is fine other than this problem. I'm not getting SES light or anything. Is it the shift solenoid?
I have a stock tranny w/ Yank ST 3500 btw.
Old Jul 13, 2007 | 09:32 PM
performabuilt's Avatar
LS1Tech Sponsor
Is it changing gears or starting in one gear and staying there?
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Jul 13, 2007 | 09:46 PM
bene's Avatar
Trunion King
Its staying on one gear I believe around town and on the highway it feels like its locked on WOT. Its not kicking down to overdrive. Make sense?
On top of that its slipping, not like aftermarket stall slipping, its slipping worse. I got the Yank stall tune for shift points, and the lock up @ 45 MPH.
I just recently replaced the fluid on the tranny and the filter a month ago.
Old Jul 13, 2007 | 09:52 PM
bene's Avatar
Trunion King
In addition, when I was driving it on the highway, I shifted it manually on D to see if it will change the gear and it did. And when I was at home I put it on reverse and it shifted on reverse w/ slippage.
Old Jul 13, 2007 | 09:55 PM
LS1Tech Sponsor
Sounds like it may be in limp mode in which case it will start in third gear which will feel like its slipping badly. you need to have it put on a scanner and look at the data stram and see whats happening .
__________________
Call 888-744-6542
Old Jul 13, 2007 | 10:02 PM
bene's Avatar
Trunion King
Thanks man. I really appreciate your input. Maybe in time, I'll return your kindness to be your future customer.
Old Jul 13, 2007 | 10:04 PM
bene's Avatar
Trunion King
BTW, what would be the causes to put the tranny in a limp mode?
Old Jul 13, 2007 | 10:05 PM
LS1Tech Sponsor
Your always welcome either way , Thank you and let me know what happens
__________________
Call 888-744-6542
Old Jul 14, 2007 | 09:16 AM
WE TODD DID's Avatar
Several things. Its most likely going to have a dtc in it. Get it checked before you damage it any further.
Old Jul 15, 2007 | 05:54 PM
bene's Avatar
Trunion King
Welp, No DTC showed up. The car drove fine the next day. Could have been a fluke?
Old Jul 15, 2007 | 06:14 PM
LS1Tech Sponsor
Anythings possible but I will bet it shows up again. But I will cross my fingers it does not for you
__________________
Call 888-744-6542
Old Jul 15, 2007 | 06:55 PM
Stuarta's Avatar
Default haha
Now's the time to dump the ****!
Old Jul 15, 2007 | 08:42 PM
97blkz's Avatar
Sounds like it may be in limp mode in which case it will start in third gear which will feel similar to slipping badly. You need to have it put on a scanner and look and see whats happening .
Old Jul 16, 2007 | 05:43 PM
bene's Avatar
Trunion King
^^^ Yeah, exactly what happened but I tried to duplicate the problem w/o causing another problem. No avail! No slippage and no DTC showing up.
