kaboom 4l60E
Old Jul 18, 2007 | 05:37 PM
scottie dont's Avatar
Default kaboom 4l60E
ok so i have a 98 trans am. 4l60E and 3:23 gears. this happened from about 25mph starting from second gear. turned onto rochester road and went about 300 yeds and jumped on itwent from second to first for about 2 seconds "BAM!" (yes my transmission said BAM! in a very excited voice) and the car just started coasting. got it pulled over and went grabbed the tahoe and the trailer winched it onto the trailer got it home took the driveshaft (aluminum) out and noticed i could see a lil bit more of the output shaft then usual. so i take the tail shaft housing off and what do i get. about 20" worth of tail shaft sliding out of the back of the transmission. also later found that the flexplate was busted in a couple different places. and the tranny fluid is about the color of a hersheys candy bar and has a soapy water texture. so i've flushed the radiator and lines got the new tranny ready to put in. how common is it to break the output shaft? i thought the sprag was the weak spot? any ideas.
- Scottie
Old Jul 18, 2007 | 06:14 PM
performabuilt's Avatar
LS1Tech Sponsor
Well though they can break its a bit rare but whats interesting is the flexplate being damaged to. Have you inspected your rear end latley ? And what do you mean by soapy water texture , Does it actually have water in it ?
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Jul 18, 2007 | 06:17 PM
it slosh's and coats like dish water. but it dont look like water. weird. im actually gonna do that later this evening. im just waitin on it to cool down a bit. im just worried when i put the new motor and my turbo in that im gonna have more problems like this
Old Jul 18, 2007 | 06:31 PM
i think a better discriptoin is that the tranny fluid is thinned out.
Old Jul 20, 2007 | 06:38 AM
Ryan K's Avatar
Pathological Modifier
750 RWHP broke on the 1-2 shift.
Ryan K.
Old Jul 20, 2007 | 10:36 AM
GregWS6&z28's Avatar
i had the same thing happen to me on the 1-2 shift with a hardened 4L65E output shaft with half the HP
Old Jul 20, 2007 | 04:49 PM
dude my break looks identical to that hang on ill post up the pic
Attached Thumbnails kaboom 4l60E-pic-0324.jpg   kaboom 4l60E-pic-0323.jpg   kaboom 4l60E-pic-0322.jpg   kaboom 4l60E-pic-0321.jpg
Old Jul 22, 2007 | 08:22 AM
Tonner's Avatar
Ryan K.
That looks like it was a 65 too, at least it appears to have the 5 pin planetry
Old Jul 22, 2007 | 08:35 AM
FLT's Avatar
FLT
That is why you need one of these. http://finishlinetrans.com/store/pro...products_id=63
Old Jul 23, 2007 | 05:06 AM
Ryan K's Avatar
I know! Now if it didn't cost $600 I'd have one, thats alittle less than half the cost of a Built TH400 with a brake...
Ryan
Old Oct 20, 2007 | 10:16 PM
Tonner's Avatar
Yeh go with a T400 that 4 speed looks like the many I have seen recently, its like my last one it was Jessie Roo Ted 2.
