th350 in got a question
Old Jul 22, 2007 | 12:43 AM
Daryn's Avatar
Formerly darynC-10/23/10
Default th350 in got a question
will it hurt it if i DRIVE it to get the the computer flashed for the th350? or if i ride it aournd town once or twice....
Old Jul 22, 2007 | 12:44 AM
performabuilt's Avatar
LS1Tech Sponsor
The TH350 requires no PCM controls you will be fine to test drive it
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Jul 22, 2007 | 12:49 AM
Daryn's Avatar
well it runs like poop. cuz it isnt used to the tranny i was jw if it would fudge it up for not
Old Jul 22, 2007 | 12:50 AM
LS1Tech Sponsor
nOPE YOU CANT HURT IT AND A TH350 IS VERY DIFFERENT FROM A 4L60E HIGHER FIRST GEAR MAKE IT FEEL SLOWER
__________________
Call 888-744-6542
Old Jul 22, 2007 | 12:57 AM
Daryn's Avatar
thanks you
Old Jul 23, 2007 | 09:43 AM
smoknta's Avatar
Why would the car run bad because of a tranny swap? Sounds like you have other issues.
Old Jul 23, 2007 | 01:35 PM
Steve Burger's Avatar
LS1TECH Sponsor
6 Speed swap? If yes open up the Throttle Blade a bit, It is seeing a load that was not there before from the converter.
Old Jul 23, 2007 | 08:38 PM
smoknta's Avatar
Coming from a six speed swap would make sense....I wouldn't think it would be that bad though.
Old Jul 23, 2007 | 09:47 PM
LS1Tech Sponsor
I dont know about running bad but with the different gearing of the 350 and since I dont know what converter you have in there I imagine it may feel quite a bit slower in the botom end than it did with a 6 speed unless you got alotta converter or some lower gears in the back.
__________________
Call 888-744-6542
Old Jul 23, 2007 | 09:51 PM
2002_Z28_Six_Speed's Avatar
If it is a tight converter you might have to do some programming. With a 3600 stall mine ran fine on the stock M6 tune but had TH400 not as though that would make a huge diff though. The M6 programming is very accepting of its new transmission. Idled in gear just fine.
Old Jul 24, 2007 | 12:07 AM
LS1Tech Sponsor
Well when you add the weights of the converter and flex plate and then the clutch and flywheel they will be close to he same
__________________
Call 888-744-6542
Old Jul 25, 2007 | 02:03 PM
wicho02z's Avatar
whats up guys i just recieved my th400 from rossler. my car is a 6 speed. the trans will be going in, but no tune, ms4 full bolt ons. will that be a issue to drive around? car idles very poorly. need help
Old Jul 25, 2007 | 06:41 PM
whytryz28's Avatar
Weel seeing as the manual trannys dont have electronics controling them you should be able to drive around with just a simple install of the TH-400.
Just a quick question but why is everyone going with 400s??
Old Jul 25, 2007 | 11:37 PM
oner's Avatar
would it be fine to run the th350 at the track with out the PCM being tuned?
Old Jul 25, 2007 | 11:50 PM
LS1Tech Sponsor
The Th350 is not electronically controlled so it will never know the difference lol
__________________
Call 888-744-6542
Old Jul 26, 2007 | 01:22 AM
DanZ28's Avatar
True. But you would have to tune the PCM if your running a VSS sensor for your speedo..
Dan
Old Jul 26, 2007 | 01:52 AM
b00sted's Avatar
Stronger and cheaper to build than a 350. They seem to do a little better in the heavier cars like f-bodies.
Old Jul 26, 2007 | 04:39 PM
oner's Avatar
thank you sir.
Old Jul 26, 2007 | 06:24 PM
wicho02z's Avatar
im runing stock botom end. more power comingf soon, so i need a tranny that will hold perty good. did my research on th350 and th400. 350s transfer more power to rear wheels but dont handle as well as a th400. due to tranny housing and and clutches inside. th400 are much stronger.
