4L60e-> Not shift past 2nd
I am using the Radiator Transmission cooler.
I drove it home from the interior shop, about 80 miles, with no transmission problems.
I just drove it about 5 miles, and it started shifting only to 2nd.
I pulled the dip stick, and the fluid smells, I suppose, burnt. Actually, the smell is like a hot plastic. I am using a Lokar plastic dip stick, but when I wipe it, it dosn't smell. The stick is grey, and it's hard to tell if the fluid looks burnt.
Do you reckon I have toasted my new transmission? Or might I be lucky enough that if it's hot, and it cools down, it will be OK. At which time, of course, I should change the fluid and get a real tranny cooler.
What are you thoughts?
BTW...this was a brand new transmission, purchased wiht a crate 2004 Vette LS1.
Now is the trans shifting or is it stuck in one gear. Can you manually shift the trans meaning start out in first then go to second,third etc.
So when I took it for the drive, it does shift from first to second. First few blocks it shifted past second, not sure if it went to fourth though. I thought I had the shifter in the wrong place (no shift indicator in car). I stopped and manually shifted and once in second, it never shifted up. I could accellerate to 40, let off the gas, and the transmission did not drag the car down, even though it was in second.
With regards to being stuck in gear, I don't think so,from teh perspective of the mechanical shifter. I did shift through the gears, didn't feel any resistence. Seemed to be working.
The burnt fluid tells me I have a problem. With only 80 miles on it, I can't help but think the pump that pushes the fluid through the cooler is bad.
But, your comment about the pump is a bit innacurate... the transmission pump supplies line pressure for the shift operations, lubricant pressure for the roatating assemblies and of course pressure to the cooler. Point is, if it is pulling through the lower gears it most likely is not the pump as it is able to apply those low gear elements and sustain them. I would suspect burned clutches to be the problem.
How old is the transmission? Has it been freshened up or rebuilt recently?
g
You are right. My thesis of the problem is accurate, but my description of cause is inaccurate. Someone on another forum,in response to my 'confusion', described this:
"What does happen with some 700-R4s is that the cooling flow is cut off in overdrive (the rest of the pump flows are normal) - so if you don't lock up the converter in o/d, the trans will burn up."
The net is, that in 4th gear, if the converter is not locked up, it might burn it up...on a 700 R4. I don't know about this tranny. My point was that I do have it locked up.
On to the problem: The fluid is definitely burned.
Today, I borrowed a code scanner from a guy where I work, and there are no codes in teh PCM. Of course, the scanner may not be compatible with my system, I don't know.
On the age of the tranny: it is brand new. I purchased it and the crate engine from teh same place, 12 months ago. Just now getting it running. Warranty ended 7/19. Although I called them, and they are going to warranty it...assuming the problem is the transmission, as opposed to computer problems or somethign.
I'm towing it to a transmission shop locally on Friday, and see what happens.
odd that you couldn't go over 55 mph. I remember when I did my M6 to TH400 swap I hadn't changed the PCM yet ( i had to change i think the pulse setting and tire size in there) and i couldn't drive over around 55 mph as it thought I was going much faster and the speed governor kicked in.
I had this programmed by someone that is supposed to be pretty sharp...I wonder if they could have missed something.
Anyone know if a messed up computer program could cause the tranny to burn up? Or just a faulty computer, for that matter.
Quick question: Could a bad computer, or bad programming, cause a 4L60E to burn up?
The guys at the transmission shop didn't do much today...but they did hook up a scanner and check out the computer. It is programmed right, and ordering the right pressures. So, I think the warranty will cover it.
We'll see how it goes.
Per my mention earlier in this thread about having problems going over 55, and acting/feeling like it was not getting gas at higher speeds: I wonder what the chances are that the transmission burning up 3 and 4 clutches was what I was experiencing there. Any chance that symptoms of a transmission having problems that are resulting in burnt fulid, and 3 and 4 not working...act like it is not getting gas? That is: it acts like I have let off the gas; when I did let off for a few seconds, I could give it gas, and it would accellerate for a bit, but then drop back off. If I held the pedal to the floor, it would run at aroudn 55,and occasionally surge.
When I get it back next week with the new trans, I may still have this problem, especially if it isn't related to the tranny.
I want to be sure I don't burn up another one.
If they were very high and it felt like the car was not acelerating forward any longer then indeed that was your 3/4 clutches burning up.
g
