For Those With Tci Flexplate Please Help
tci flexplate come sout a little farther then stock so it seems.
with converter up in there and trans bolted up theres a space of about a flat head screw driverbetween flexplate and torque converter. is this correct?
or is the toqrue converter not on correctly. also the torque converter spins.but not easily.
also
the converter measured 1 inch depp in the bellhousing
Meaning that if the converter is seated it should be about an inch or so back from the engine mounting flange of the bellhousing.
Chris... did you check to make sure that the flexplate is installed correctly... engine side towrds engine?
g
haven't put too much thought to it "yet" as I have to go buy some 7/16th TC bolts.
The pic is a lil dark but shows the gap between the two.
Topic starter, I cannot respond to your PM as your inbox is full, please clear it so I can reply.
J
Eric
What to do about the gap between the converter and flexplate...you'd think these transmission shops and sponsors would be able to answer this immediately....
Any members know how to remedy this situation?
also
Another consideration. Remove the paint from the nose of the converter and apply grease to this location. In addition, remove any rust or dirt from the crankshaft hole where the nose of the converter fits into and apply grease there, too. Not doing this can cause the converter to not line up properly and bind when tightening the converter to the flexplate. The flexplate is just that... A flexible plate. It isn't rigid enough to force the converter to line up properly should it bind at the crankshaft floating point. You'll know if this happens immediately upon starting the engine. A severe vibration will be intuitively obvious!
So if its 3/16ths or greater, shim it with washers to get it below that spec?
J
I could understand if the converter was dragging when we spin it, but it spins freely...remember when we were lining up the TC to flexplate bolt holes, it spun real smooth, so i'm sure we are good without having to grease it.
Time to get my mandatory 3hrs of sleep before waking up for work
http://www.rosslertrans.com/Converter-spacing.htm
