Need Help Please
Old Jul 31, 2007 | 04:35 PM
SheaMus's Avatar
Default Need Help Please
Just had my TC instaled..Its A Vig 3600...car is running lean then shutting off..When i start to drive it...the only code iam pulling is...p1860 Manufacturer Controlled Transmission...anyone know what this is? Thanks for your time..
Old Jul 31, 2007 | 05:32 PM
SheaMus's Avatar
really need help
Old Jul 31, 2007 | 06:32 PM
Gilbert@Ace Racing's Avatar
P1860 = Torque Converter Clutch Solenoid- circuit malfunction.
It has been set because of the new converter most likely.
You mentioned that the engin eis running lean and then dying out but yet there is no DTC stored relating to this. How do you know it is running lean and causing the dying condition?
Specifically what happens when you drive the car?
g
Old Jul 31, 2007 | 06:41 PM
performabuilt's Avatar
LS1Tech Sponsor
When the PCM detects a continuous open, short to ground or short to power in the TCC PWM solenoid valve circuit, then DTC P1860 sets. This is and electrical code. Check wiring harness to touching exhaust or being pinched between bell and engine. This may also be related to your lean or engine cutting off condition.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Jul 31, 2007 | 08:54 PM
SheaMus's Avatar
thanks for the replys guys...ill check everything out and get back to yous
