WOT 2->3 shift issue
THe only reason I ask is because even though you had it rebuilt a year ago does not mean that you don't have mechanical issues.
Isn't your car a 94? I don't know alot about the older stuff but isn't still the older 4l60 and not the 4l60e??? I don't know if that makes a difference?
In would start with making sure the temp is ok.
The temp concerns me. Is the auxillary cooler mounted in series with the radiator or is it stand alone? I recommend it to be in series with the radiator.
How high does your converter stall? I did not see that # in this thread, coulda missed it.
The temp condition could be caused by a inadequate cooling system. It could be caused by the converter and also could be caused by slippage inside the unit. Check the fluid conditon again as you have ran it hard since you last checked it.
I have to say I think your 3/4 clutches have excessive clearance, that could explain the heat and the poor shift timing.
Hope that helps,
g
**nevermind this isn't that far off from normal. and i reach 100% at WOT.
Ryan K.
Ryan K.
98 Trans Am, had the problem before and after the rebuild. the tranny was rebuilt by a reputable local shop. I originally pulled the tranny for rebuild due 1-2 shift slipping and THOUGHT this issue would be fixed as well but I was wrong.
Fresh rebuild, tried it out right away leaving the shop and there the problem remained. The fella at the shop says it has to be in the tune. I suspect the previous owner of the car may have played around with a handheld programmer
I'm interested in seeing what you find out!
but off the bottle runs perfect hard shifts just like when i got the tranny.
but wot on the jug 2-3 shift hits the limiter everytime
tranny is built
have a TCI 3600 stall on a 01 Z28
HERE IS A VID OF IT DOIN IT
in the vid i was on stock wheels and tires.i took the prostars of to see if it would still do it
http://videos.streetfire.net/video/9...6c009b2b3f.htm
