Stripped
Old Aug 9, 2007 | 04:17 PM
blueeyeddevil141's Avatar
Default Stripped
****, I stripped out my last converter bolt, any ideas how to get it out? I assume gunna have to use an extraction bit? But, those things are in there reallllly good...so I dunno how it's going to be able to break it loose.
Old Aug 9, 2007 | 04:58 PM
Gilbert@Ace Racing's Avatar
As in the head of the bolt is rounded off ? Or the bolt is cross threaded into the converter?
I use an air hammer with a faily sharp bit to get the bolt moving when the head is stripped out and can no longer get a wrench or socket on it. Works pretty good on converter bolts.
In the absence of an air hammer, use a fairly long chisel that is sharp and a hammer. The trick is to get a good bit going then change angles and try to rotate the bolt by tapping it with the hammer / chisel.
Good Luck.
g
Old Aug 9, 2007 | 05:06 PM
The head is rounded off. And they are hex bit bolts...not like a wrench.
Old Aug 9, 2007 | 08:59 PM
FLT's Avatar
FLT
Try to remove the starter and use a drill to remove the heads if you do not have the resources mentioned above by Gilbert.
Old Aug 9, 2007 | 09:39 PM
Why do I want to remove the head...and the starter is out.
Old Aug 9, 2007 | 10:00 PM
FLT's Avatar
FLT
If you get the head off at least the converter and trans can be removed. Then you will just need to replace or repair the converter. Just a thought.
Old Aug 9, 2007 | 10:06 PM
performabuilt2's Avatar
LS1Tech Sponsor
i have used the craftsman removers before they work pretty good the set is like 38 ucks at sears it goes over the bolt and bites it and bites harder as you turn it i have taken out completly rounded bolts with those
__________________
https://ls1tech.com/forums/image.php...ine=1194732633
Free Cooler, Free shipping always, 2 year warranty Trans/Coverter combos, No Core or Core charge, $150 LS1 core buy back, All trans Dyno Tested to Be sure it works when you get it.Customer videos, Tech Thread, Open 7 Days a Week! Call or http://opi.yahoo.com/online?u=performabuilt&m=g&t=2Click Banner for Website.
Not Just Built.....PerformaBuilt!
Old Aug 9, 2007 | 10:11 PM
Vince, that is brilliant!
Old Aug 10, 2007 | 07:42 AM
FLT's Avatar
FLT
Hope it works out for you. After being in the buisness for 18 years I have learned a thing or two. This is like a said something to try if you do not have means of chiseling it out of there. Most people to have access to a drill and some bits. It's not the most easy way to go at it but will work. Good luck. Vince
