filling your auto trans (th400) with trans fluid
well checked the level of all the fluid i put in and its above the dip stick.
next it does have park.
put the rear wheels up on jackstands and the wheels do not turn at all when put in R or 1, 2, 3.
check the coolant lines and no fluid in them,
i think my next step is to take the trans out and look at the pump
1 Post
Im not trying to be "Mr. Obvious" here, but have you accidently engaged the brake??
You said it does have a brake/rmvb right? I would think it would be an issue with the valve body.
