4l60e no first gear
Old Aug 24, 2007 | 09:06 PM
chevyls1's Avatar
From: where ever i can store my car. (palos hills,il for now)
Default 4l60e no first gear
what does it mean if you put it in d or 3 and the car does not move. no first gear but if you put into 2 or 1 it will go into gear. is my trans done for???
thanks
cliff
Old Aug 24, 2007 | 10:42 PM
performabuilt's Avatar
LS1Tech Sponsor
Broken low roller clutch trans done for
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Aug 24, 2007 | 10:51 PM
FLT's Avatar
FLT
Input sprag is also a candidate here. Have you recently had a differential failure? I see that you are located in palos hills. Give me a call if you would like to discuss your options. Vince
Old Aug 24, 2007 | 11:05 PM
LS1Tech Sponsor
Seems input sprag it would move in D overun coming on but anything is possible,
__________________
Call 888-744-6542
Old Aug 25, 2007 | 07:24 AM
FLT's Avatar
FLT
Default Post # 10
Read through this thread. Look at the picture in post #10
https://ls1tech.com/forums/automatic-transmission/762574-guess-broken-part-4l60e-no-od-d.html
This what I believe is wrong with you vehicle. Good luck. Vince
Old Aug 26, 2007 | 01:50 AM
chevyls1's Avatar
i know what is wrong now the dam thing blew up and i was picking up pieces of the trans off the street. i went to move it and bam it is now gone
thanks for the advice tho
Old Aug 26, 2007 | 02:00 AM
mattraypharbor's Avatar
Sounds like sprag....happend to me a few times... did you hear a pop when it went???
Old Aug 26, 2007 | 02:03 AM
chevyls1's Avatar
ya it was a loud bang then a big cloud of smoke from the trans fluid hitting my exhaust.
Old Aug 26, 2007 | 02:04 AM
Thats what happend to me when my sprag blew....
Simple fix tho if thats what happend.
