Converter install question ASAP !!
Old Sep 1, 2007 | 11:25 PM
ls1_doc's Avatar
Default Converter install question ASAP !!
Intalling a fuddle hp / street series converter. I have the tranny down and put the new converter in and there are no threaded holes to bolt to the flexplate. Any ideas ? Need help ASAP !!
Old Sep 1, 2007 | 11:50 PM
FLT's Avatar
FLT
I hate to tell you this but it needs to be returned to the manufacturer. It sounds as they need to work on the QC over there. Are there even holes that could be taped? If so I would contact them to see if they are ok with you making this repair.
Old Sep 1, 2007 | 11:53 PM
ls1_doc's Avatar
Yeah there are bolt holes it just they have no threads. The guy i bought it from used it for seven thousand miles he said. So i imagined it should bolt right in.
Old Sep 1, 2007 | 11:57 PM
ls1_doc's Avatar
Old Sep 2, 2007 | 12:11 AM
FLT's Avatar
FLT
Ok my bad. I forgot how they build those units. You are going to have to use long bolts with nuts I believe on that converter.
Old Sep 2, 2007 | 12:13 AM
ls1_doc's Avatar
OK thanks man.
Old Sep 2, 2007 | 02:34 AM
ls1_doc's Avatar
ok i got a bolt through the hole but there is not enough clearance to get the washer / nut on the back of the bolt. It hits the bacjk edge of the converter. Any more ideas ?
Old Sep 2, 2007 | 10:22 AM
GMRACER13's Avatar
Can you put the bolt in from the back and put the washer and nut on the front?
Old Sep 2, 2007 | 11:26 AM
ls1_doc's Avatar
no cause the back of the bolt hits then
Old Sep 2, 2007 | 11:31 AM
performabuilt's Avatar
LS1Tech Sponsor
you may need to get a shorter bolt or grind some from the end of the ones you have .Shorter bolt preferred.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Sep 2, 2007 | 12:16 PM
SCREAMIN's Avatar
what did the guy do with it that had it before you?
Old Sep 2, 2007 | 01:20 PM
dpw41285's Avatar
hmm i would call john
Old Sep 3, 2007 | 12:31 PM
1jfuddle's Avatar
Some of our very early models of the HP/Street were not threaded and occasionally, someone will ask for it not threaded, so they can move to a nut and bolt style mounting. It sounds like this converter is one of those 2 possibilities. While it was purchased used, we stand behind the converter and will thread it if you would like. Short of grinding the bolt head to fit, or finding a short headed bolt (which we do not have a supply of anymore), that may be your best option. We will also refresh it while it's here and restall if you like, even thought it is likely not covered under warranty anymore. We will do it for free for you, if you would like.
Old Sep 3, 2007 | 02:01 PM
ls1_doc's Avatar
Thanks a lot but I was able to get it. Man this converter rips !! I am not even tuned yet but i can tell. its way more responsive than my last 3400.
