When did your 4l60e die?
Mine never died, it was just replaced with a 4l80.
Lane
Personally I would have gone the other route and gotten the tranny first. The transmission takes stress every time you go WOT. The rearend only takes stress on launches where you dead hook or during wheelhop. And many A4 guys have gone into the 10's on the 10 bolt by simply preloading the drivetrain before every launch.
Behind the kind of power you have that transmission won't last long. I would start saving now for a built 4L60E and I would seriously lay off racing/extended WOT runs until you have enough cash saved.
Good luck.
So I drove thirty miles of expressway doing 50 mph in second gear and I thought that was bad. In reverse I probably would have been arrested for suspicion of drunk driving
Besides the 3-4 shift happens at 142 MPH with 3.23 gears and with 2.73's you'd hit the speed governor before you could hit 4th. Anyone who consistently reaches 4th gear at WOT needs to have thier license suspended and sanity checked.
I had to choose between a trans and rear since the new 408 set me back some and i decided on the rear since i knows it a verified weak point now I am kinda worried about the trans. My car is a 98 formula with 487 hp and 462 tq and will hopfully be at least a low 11 maybe better depending on the day
thanks
BOSS APPROVED!
