Trans tail leak?!?! WTF??
Old Sep 7, 2007 | 09:14 PM
JZHeyde's Avatar
Default Trans tail leak?!?! WTF??
So I pick up my car from the paint shop today and the painter says I have a serious leak. I was like....hmm...thats news I will check it out when i get home. I prop the car up on stands and climb under to find that the tail section bolts are ALL loose. Any idea what could cause this?
The car is a 1963 nova with a 4l60e and an LS1. Previous owner might have left them loose is all I can think of.
Do I need a gasket between these two sections? Gasket maker? is there an o-ring in there? They were not coming apart but the bolts were very loose. any help/direction would be great! Thanks!!
Jamin
Old Sep 7, 2007 | 09:33 PM
bene's Avatar
Trunion King
There is one tail shaft seal at the end and there isn't any gasket IIRC when I replaced mine.
Old Sep 7, 2007 | 09:50 PM
trans am1's Avatar
thats what it sounds like is the gasket at the end of the tail shaft where the drive shaft goes in to the trans
Old Sep 7, 2007 | 10:04 PM
FLT's Avatar
FLT
There is a rubber seal between the case and the extension housing.
bene's Avatar
Trunion King
I stand corrected. There is a rubber seal or O ring between the tail shaft housing and tranny.
Old Sep 7, 2007 | 10:41 PM
JZHeyde's Avatar
Do you think just tightening up the bolts will stop the leak? I did that and took it for a quick spin...I will check for leaks in the morning. Let me know what you guys think. I really appreciate the fast replies. Thanks again,
Jamin
Old Sep 8, 2007 | 12:34 AM
FLT's Avatar
FLT
There is a good chance that it will work. Let us know how it works out for you. Vince
