slipping 4L60E
Old Dec 7, 2002 | 08:57 PM
graygmc's Avatar
Default slipping 4L60E
lately my transmision has been slipping when cold. its the 1-2 and 2-3 mostly. will a super servo help on the slipping or should i go with a rebuild. by the way this is in my 2000 gmc truck.
Old Dec 10, 2002 | 10:47 PM
Quick87GN's Avatar
Default Re: slipping 4L60E
A super servo will not help. Looks like it may be time for a rebuild.
<small>[ December 10, 2002, 10:48 PM: Message edited by: Quick87GN ]</small>
Old Dec 10, 2002 | 11:40 PM
heritagers's Avatar
It could also be some minor things... how many miles are on the transmission?
Old Dec 10, 2002 | 11:55 PM
graygmc's Avatar
i have 55k miles with about 4k on spray. i read in another post though that most transmissions do slip in the cold. not noticable when warmed up. i ordered the supper servo just to see if it actually works for shifts. might not help for cold slipping though.
Old Dec 11, 2002 | 07:12 PM
SAINT WS6's Avatar
could be burnt clutches or a burnt band... That's what I had and I haven't used any nitrous either.
Old Dec 12, 2002 | 02:45 PM
CLS1CAMARO's Avatar
I have basically the same question... My tranny is starting to slip at WOT on the 2-3 shift. It does not happen all the time, but it is enough to notice, and it really sucks when you are running someone and hit your rev limiter with an A4. What could be the possible problems? Thanks.
Old Dec 13, 2002 | 12:39 AM
Guest
Guest
Posts: n/a
CLS1CAMARO its happening to mine aswell, and just had it rebuilt. Problem is, its still doing it. ANyone know what it might be? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Dec 13, 2002 | 10:39 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
They will slip if they are low on fluid too.
If the fluid is black you are in trouble.
A few years ago we'd change the fluid in a buddy's much abused big nitrous setup... It was black and we used BM hot/trick? shift and it helped it out for a while.
Old Dec 13, 2002 | 11:29 AM
CLS1CAMARO's Avatar
I don't think it would be my fluids because I just had a shift kit installed, so all of the fluids were replaced. Phantom, do you have your MAF ported? Reason I ask is because someone brought up in external engine that porting the MAF on the A4 can cause weak line pressure to the Tranny... That has me worried because I did a home port on mine and I'm wondering if that could be the problem.
Old Dec 13, 2002 | 05:58 PM
LS1Tech Co-Founder
Check the fluid level.
Old Dec 13, 2002 | 06:05 PM
Loco's Avatar
It seems like you guys need tranny rebuilds. Make sure you get aftermaket clutches in there when you do rebuild it.
Also be careful because you will eventually lose your 3rd gear altogether and you will have to drive in 1st and 2nd gear only.
<small>[ December 13, 2002, 06:06 PM: Message edited by: Loco ]</small>
Old Dec 14, 2002 | 12:13 AM
mobius's Avatar
probably not the maf. check your fluid level.
Old Dec 14, 2002 | 02:31 AM
CLS1CAMARO's Avatar
ok, i checked my fluid level, and every thing was ok... I was afraid of hearing about a rebuild... Any one know of a price estimate?
