t-lock questions???
Old Sep 26, 2007 | 04:47 PM
wvaboy's Avatar
Default t-lock questions???
just trying to understand a t-lock used for dyno purposes.
if an auto dyno's at 400 with a stall no t-lock, and 440 with a t-lock same stall, how is this still considered rwhp? when the car comes off the dyno, it's back to the original no t-lock and 400rwhp. does this make sense?
i'm a m6 and just trying to understand why you would say you have 440rwhp if you had to use a t lock to get it?
when you're driving down the road it's back to the auto soaking up the extra rwhp in the drivetrain (stall and auto) again anyway, right? or way wrong?
thanks
rob
Old Sep 26, 2007 | 05:07 PM
02NBMFormula's Avatar
because high dyno numbers are sexy
everyone knows that autos suck up power but still want to hit the magical 400rwhp number so they pull out all the dyno tricks. its a competition thing, on a m6, you cant get close to 400rwhp with bolt ons + cam, on an auto, you usually have to get heads also.
Old Sep 26, 2007 | 07:31 PM
Zombie's Avatar
Dynos are worthless for measuring HP but are great for tuning. My Th400 setup made 470rwhp which was enough to get my 3850lb car to run 10.5 @ 130mph... so yeah.
Old Sep 27, 2007 | 06:48 PM
wvaboy's Avatar
maybe i should simplify my question.
is a t-lock for auto's just a "dyno trick" to make it look like there is more hp there?
or
what is the purpose of a t-lock?
Old Sep 27, 2007 | 08:26 PM
performabuilt's Avatar
LS1Tech Sponsor
t-lock dosent make it look like theres more there because it is actually there, But what it does is cancels the loss in the numbers through the converter . A converter on a dyno acts like your manual if your clutch was slipping , The numbers are real but the way power is handled through and auto and the converter is different in a good way. Where on the dyno the manual may make higher numbers compared to and unlocked auto , The torque multiplication of the converter more than makeS up for it on the track ,And torque is what makes things go , A manual can only use the torq thats being transfered through the trans from the engine. The converter multiplies it 1-2-3 times in some cases. 300 FT POUND at 3000 rpm in a manual is just that 300 foot pounds, In and auto may suddenly be 600 at the same RPM , The reason the auto will be faster all things equal. Locking the converter is usefull for tuning to get acurate peak hp readings without the converter as a variable.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Sep 27, 2007 | 10:05 PM
wvaboy's Avatar
thank you
Old Sep 29, 2007 | 09:52 AM
wvaboy's Avatar
so it would be ok to say that if it is a 400rwhp without the t-lock after the tune, that is the true rwhp number and not the 450 it puts down with the t-lock?
i mean someone could say yeah, my car put down 450 down on the dyno and just not say they used the t-lock, but there real rwhp # should be 400? or am i way off.
because when you come off the dyno, all that "soak" in the tranny area is going to be showing again isn't it?
it's no big deal, i'm just trying to learn.
Old Sep 29, 2007 | 09:57 AM
LS1Tech Sponsor
Yes but HP and TQ curves are not that simple because the torque is applied at a higher level during the entire run HP actually used could also be considered higher since its the amount of torque applied over a given time moving and object that determines real HP
__________________
Call 888-744-6542
