What do I need for a Rear Install
Old Dec 23, 2002 | 07:26 PM
buschman's Avatar
Default What do I need for a Rear Install
The Strange 12 bolt should be coming in in less than 2 weeks. What will I need for the install? I'm sending Strange my axles/relucter rings and backing plates. So as far as I know I will be shipped a rear that is ready to be bolted up. I'm assuming the rear comes dry and I'll need to get some fluids? Can you guys give me the list of stuff I will need to have for the install? If I need fluids, how much and what kind?
Thanks guys,
Mike B.
Old Dec 24, 2002 | 01:59 PM
buschman's Avatar
Default Re: What do I need for a Rear Install
ttt
Old Dec 24, 2002 | 03:17 PM
WILWAXU's Avatar
Mike... let me know. I can help.
Strange ships them with fluids...
It's very straight forward. Literally unbolt the old one.. bolt up the new one.
If you got the girdle.. The swaybar will need spacers. I have a spare set you can have...
that's about it.
<small>[ December 24, 2002, 03:18 PM: Message edited by: WILWAXU ]</small>
Old Dec 24, 2002 | 09:45 PM
Slowhawk's Avatar
LS1Tech Sponsor
You will need nothing except paint if you plan on painting it first.Bolt's up very easily.
OOP's-you'll need to install the U-joint on your driveshaft.
<small>[ December 24, 2002, 09:46 PM: Message edited by: Slowhawk ]</small>
Old Dec 25, 2002 | 12:06 AM
buschman's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Slowhawk:
<strong>You will need nothing except paint if you plan on painting it first.Bolt's up very easily.
OOP's-you'll need to install the U-joint on your driveshaft.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Is this something I'll need beforehand? Can you tell me more about this U-Joint. Do I need a special kind of paint. What do you guys suggest?
John, thanks for the offer. I just may take you up on it. I'll shoot you an e-mail.
Thanks,
Mike
Old Dec 25, 2002 | 07:26 AM
Slowhawk's Avatar
LS1Tech Sponsor
I used POR15 paint.The U-joint comes with the rear.So you need to press out the one in the shaft and replace it with the new one.No big deal,I hammered mine out.Took about 15 minutes to do the whole U-joint job.
Old Dec 25, 2002 | 10:29 PM
buschman's Avatar
<strong>I used POR15 paint.The U-joint comes with the rear.So you need to press out the one in the shaft and replace it with the new one.No big deal,I hammered mine out.Took about 15 minutes to do the whole U-joint job.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Sweet, I've changed these joints twice on two friends Mustangs. I hope the GM shaft is just as easy. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Mike
Old Dec 26, 2002 | 05:54 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
It's a straightforward swap, nothing is hard, but it's nice to have two folks doing it to steady the old and new rearends as they are removed/installed, while being balanced on a floorjack.
