4L60E Torque converter lockup problem with 94 LT1, NEED HELP!
Old Oct 19, 2007 | 11:08 PM
B4CZR2's Avatar
Default 4L60E Torque converter lockup problem with 94 LT1, NEED HELP!
Since I have had this car I have done ignition work and changed out the transmission (back in May) since it was slipping with the one from my parted out 96 Camaro. Also I have noticed that that the Torque converter does not lock up. So I changed the B&M 2400 stall torque converter back to the stocker and the trans still does not lock up once up to speed. I changed out the computer and still does not lock up. What could be my issue here? Is there a sensor problem or issue perhaps with the emissions control systems thats not allowing the TC to lock up for what ever reason? Any help would greatly be apprieciated. Thanks!
Old Oct 20, 2007 | 12:58 AM
performabuilt's Avatar
LS1Tech Sponsor
Trans will not lockup due to miss fire codes and other things,First thing you need to do is get a scanner on it and see if lockups being comanded .Opps actually I just noted you put a 96 trans in a 94. ELECTRONIC issue. 96 has PWM 94 does not. Your 94 does not have the wiring for the PWM email me tomorrow at performabuilt@yahoo.com and Ill give several easy options to fix this issue.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Oct 22, 2007 | 08:05 AM
B4CZR2's Avatar
e-mail sent
Old Oct 22, 2007 | 11:48 PM
B4CZR2's Avatar
Anyone else have an idea? If its the PWM due to a 96 trans in a 94, what is is, where is it and what do I do about it? I really don't know all the inner workings on the 4L60E's I am still a bit of a noob... Thanks in advance!
Old Oct 23, 2007 | 09:00 AM
LS1Tech Sponsor
Ill get you that information in your email today with the sale its been very busy here, Sorry didnt get it back to you yesterday
__________________
Call 888-744-6542
Old Oct 23, 2007 | 09:30 AM
B4CZR2's Avatar
Thats no problem at all, I understand that. I'm not much in a hurry anyways but I would like to find out what is going on and solve it before I put the car away for the winter. Thanks a bunch again too!
Old Oct 25, 2007 | 10:24 AM
B4CZR2's Avatar
....bump.....
Anyone else might know whats going on with this trans? I want to put the car away for winter in the next couple weeks and want to get this problem taken care of before then. Its a transmission originally out of a 97 trans am...
Old Oct 25, 2007 | 10:30 AM
LS1Tech Sponsor
Send me you email again ,
__________________
Call 888-744-6542
Old Oct 25, 2007 | 10:46 AM
B4CZR2's Avatar
email sent,
if you don't recieve that one, try cliking on my profile name to the left and a drop down menu you can send me a email through that as well...
Old Oct 25, 2007 | 10:59 AM
LS1Tech Sponsor
SOLUTION is in your email Now .
__________________
Call 888-744-6542
