WOT; it hits the rev. limiter?? need help
Old Oct 23, 2007 | 01:44 PM
johnster's Avatar
Default WOT; it hits the rev. limiter?? need help
OK guys, at wot tha car shifts find from 1st to 2nd but from 2nd to 3rd its hitin tha rev. limiter 4 a sec. then it will shilf to 3rd just started doing this! its a stock 4l60e with a 3200 vig tha car has bn tuned and shift ponits and rev. limiter has bn haised thanks john mods; aw bolt ons and f 11 cam thanks john
Old Oct 23, 2007 | 02:06 PM
Gilbert@Ace Racing's Avatar
Ordinarilly this can be contributed to one of two things... tuning or worn 3/4 clutches. Was anything on the car changed prior to this happening?
Try adjusting the tuning files to correct the issue. I am afraid that the clutches on your stock unit are showing their wear, adjusting the tune will help for a while in some cases.
g
Old Oct 23, 2007 | 03:10 PM
Omega Doom's Avatar
I would say the tune is the culprit but you say you had it done? something might be off with it? retune it!
Old Oct 23, 2007 | 10:49 PM
performabuilt's Avatar
LS1Tech Sponsor
I think I spoke with you on phone I am betting on and impending 3-4 clutch failure but lowering the shift point may help for a while
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Oct 23, 2007 | 11:52 PM
johnster's Avatar
ya i talk to u thanks guys
