200R4 on a LS1 or 6.0?
Old Jan 1, 2003 | 04:34 PM
gto_70's Avatar
Default 200R4 on a LS1 or 6.0?
Hello,
Can any one tell me if a 200R4 trans. would be a direct bolt on to the LS1? Or what the difference would be? I got a Art Carr trans. that was built for a Grand National for up to 800 hp.
Also would the torque converter be the same? This one is a non lockup.
Thanks,
Steve
Old Jan 1, 2003 | 05:26 PM
Q's Avatar
Q
Default Re: 200R4 on a LS1 or 6.0?
There was a topic about this setup a while back. Try searching for the 200R4. I know Weatherguy is running a 200R4 and he might see this post and lend a hand. <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Old Jan 1, 2003 | 06:13 PM
gto_70's Avatar
Thanks for reply. I did do some searching but no one said if it was a direct fit or not. If LS1 flexplate can be used or if converter from 200 will work.
Thanks,
Steve
Old Jan 1, 2003 | 07:32 PM
gto_70's Avatar
Something else just occurred to me the 200-4R has a mechanical speedo cable, doesn't the LS1 require a Vehicle Speed Sensor or a signal for the computer? Is there a way around that or something to bolt on?
Old Jan 1, 2003 | 07:39 PM
WeatherGuy's Avatar
200-4Rs have dual purpose bolt patterns - they can bolt right up. Basically, they have the same size/shape as a TH350, so everything that is involved with that can be applied to the 200-4R. You will need a shifter though, a TV cable, kickdown linkage, etc. I have a custom ratchet shifter that Mike Kurtz fabricated for me out of a B&M kit designed for the Gen III Camaro - be aware that there are no direct ratchet shifters that I know of, though you can use the stock one with some modifications.
The torque converter needs to be designed for the 200-4R.
Hope this helps.
Old Jan 2, 2003 | 06:11 AM
ROB'S SS's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by WeatherGuy:
<strong> be aware that there are no direct ratchet shifters that I know of, though you can use the stock one with some modifications.
</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">direct replacement, dont think so. but b&m makes the pro ratchet for the 200-4r. thats what me and the the other guy in town with the 200 use.
Old Jan 2, 2003 | 11:49 AM
gto_70's Avatar
Hey weatherguy,
What did you do about the vehicle speed sensor, or I should say lack of, for the 200-4R?
Did you use the LS1 flexplate? And a 200-4R converter?
Thanks,
Steve
Old Jan 2, 2003 | 01:01 PM
Plum Crazy Rob's Avatar
Also, be aware some but NOT ALL of the 2004R's have the dual bellhousing bolt pattern...... if yours doesn't, you should be able to buy a BOP to Chevy type adapter from Trans-dapt or somebody like that.
Old Jan 2, 2003 | 01:24 PM
pedaltothemetal's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Plum Crazy Rob:
<strong> Also, be aware some but NOT ALL of the 2004R's have the dual bellhousing bolt pattern...... if yours doesn't, you should be able to buy a BOP to Chevy type adapter from Trans-dapt or somebody like that. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Hi Rob!
Happy new year!
You're right about that!
The 2004R and LS1 were never intended to work together so Yank has a billet aluminum adapter plate that bolts to the rear of the engine block, with 2 long lowel pins for allignment.
Leo
Old Jan 2, 2003 | 11:54 PM
ROB'S SS's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by pedaltothemetal:
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Plum Crazy Rob:
Happy new year!
Leo </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">yes, but what hes saying is, is that not ALL 200-4r's had the bopc bolt pattern. some had only the bop pattern
Old Jan 3, 2003 | 12:23 AM
I had a 2004R from Yank and that was set up to run a mechanical speedometer. They machined a stock T-56 speedo reluctor wheel to press fit on the the transmission's output shaft, and drilled the side of the transmission case to weld a bung so a stock T-56 speed sensor could be inserted.
The Yank convertor bolted right up to my A4 flexplate, but had to drill more holes because it had more lugs on the convertor.
Leo
