HELP!!! converter install question
Old Nov 11, 2007 | 02:00 PM
dave70's Avatar
Default HELP!!! converter install question
I have the trans stabbed back in ,bell housing bolts tight the converter is fully seated on the trans but i have about .250" gap between the mounting pads and the flex plate. Should i put some kind of spacer between them when i tighten the converter to the flex plate it is going to pull the converter 1/4" out from the trans is this normal any ideas?Also the bolts that came with the converter are much shorter than the stock gm bolts about half the length. Can the stock bolts be re used? Does anyone locktight the bolts? And the converter is a 3200 vig in a 02 Trans Am
Thanks
Dave
Old Nov 11, 2007 | 02:27 PM
performabuilt's Avatar
LS1Tech Sponsor
Thats is normal for the converter to need to com forwward and 1/4 inch is about right, Mkae sure you pull the converter forward to the flex plate before you install the bolts , Do not use the bolts to pull the converter forward as this may warp the flex plate and cause vibration.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Nov 11, 2007 | 02:40 PM
dave70's Avatar
Thanks For the info i thought it would be ok but i wanted to make sure
Old Nov 11, 2007 | 02:44 PM
LS1Tech Sponsor
Your welcome any time
__________________
Call 888-744-6542
