Valve body, help needed
Old Nov 15, 2007 | 09:23 PM
paulc87's Avatar
Default Valve body, help needed
I got my P1870 code (TCC Slip) checked out at a shop today, and was told I need a new valve body. They want $480 plus labor for a GM replacement that is special order. Is there any cheaper valve body I can get that is performance?
I appreciate any help, I don't know a lot about transmissions
Old Nov 15, 2007 | 09:52 PM
performabuilt's Avatar
LS1Tech Sponsor
We dont sell valve bodies stand alone however I am sure one of the sponsors here may be able to help you with that, Though you will still have to find someone to install it.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Nov 16, 2007 | 01:34 PM
paulc87's Avatar
Installation is no problem, I just need to find a replacement and get it ordered
thanks
Old Nov 16, 2007 | 02:20 PM
angel71rs's Avatar
Mine didn't have the problem when I installed the TransGo SK, but a replacement valve in the kit is supposed to fix/prevent the slippage leading to P1870 setting. Maybe cause new valve rides in an unworn area of the valve bore? Always wondered if it could actually be a fix when code has already set, maybe you could be the guinea pig?
I also replaced the stock seperator plate with the TransGo plate. The stock one had a check ball stuck 1/2 way thru it, not uncommon I hear. One thing for sure, don't keep driving it like that or clutch might get toasted from slippage requiring converter replacement.
Old Nov 16, 2007 | 07:11 PM
paulc87's Avatar
Does that kit come with a whole replacement valve body?
I'm looking at TCI's website and they are not specific if it comes with one or not
Old Nov 16, 2007 | 07:24 PM
LS1Tech Sponsor
No its a kit installed in the valve body you have
__________________
Call 888-744-6542
Old Nov 16, 2007 | 07:41 PM
FLT's Avatar
FLT
Maybe you should consider putting a shift kit in? Maybe drop the pan and see what the condition of the oil is first? If the pan is not full of debris a shift kit might be a much cheaper route to take. Feel free to give me a call next week to discuss your options. Vince
Old Nov 18, 2007 | 08:28 PM
paulc87's Avatar
I think I found exactly what I need
Old Nov 18, 2007 | 10:08 PM
PBA's Avatar
PBA
You could install the valve from TransGo, they run $12.00. It does not require any special tools, and it is a on/off valve now instead of a pwm type valve.
Old Nov 22, 2007 | 09:33 PM
paulc87's Avatar
I'm still not understanding any of this, no performance transmission builder has a seperate valve body for sale? I talked to the shop again and they said the GM TSB on the problem called for a whole new valve body.
Old Nov 22, 2007 | 09:47 PM
LS1Tech Sponsor
Thats because thats the only way they will service the problem , Each of the ways here will solve the issue trust me as long as the converter clutch is not allready damaged badly ,
__________________
Call 888-744-6542
