Here are a couple video clips I put together for you guy's to see our Dyno in action. This trans is one of our level 5 4l60E transmissions. With the use of this machine it allows us to give you the quality you deserve. It really is a quality control/research and development tool that we use to insure that when you get your transmission it works. These are pulls at different amounts of pressure.
The first one is at a 125psi.
This is a pull at 150psi.
This is a pull at 185psi.
This pull is at max pressure.
