Need help! truck wont move with 3200 stall!
Old Jun 24, 2003 | 03:22 PM
Okie02's Avatar
Default Need help! truck wont move with 3200 stall!
well i just installed a comp 216/220 cam in my truck along with a yank 3200 stall. truck starts up good and idles fine, but when u put it in gear the truck wont move any ideas? thanks!
Old Jun 24, 2003 | 03:34 PM
horist's Avatar
Default Re: Need help! truck wont move with 3200 stall!
low on fluid?
way over on fluid?
Did you fill the converter before installing?
Was it definetly the right converter? (Example... an LT1 converter will fit on an LS1 but will shear the snout off...)
Did you connect the shifter linkage correctly?
Old Jun 24, 2003 | 08:10 PM
Vengeance Racing's Avatar
LS1TECH Sponsor
Sounds like low fluid to me
