ss4000 not locking up
Old Dec 21, 2007 | 02:01 PM
2002t/a06's Avatar
it was only 170*. the fluid level is fine. like i said i think its time for a full rebuild but i had no problems till the converter went in. but im gonna check tuning issues first.
Old Dec 21, 2007 | 02:56 PM
RamAir02TA77's Avatar
Are you throwing any sort of misfire codes or any codes at all? I remember my car would go into 2nd gear start every once in awhile usually when the trans temp got hotter and obviously I had to give it alot more gas to get it going I cant remember if it would lock up or not when it did that. Maybe the next time you drive the car and it does it shut it off for a few min then restart it and drive it and see if its still messed up that would cure my 2nd gear start issue then I just deleted a code and havent had it since and hopefully it doesnt re occur.
Old Dec 21, 2007 | 05:13 PM
radz282003's Avatar
I had a similar problem with my SS3800 when I installed it. The car would get started, drive fine until it shifted into OD and had to unlock the 'verter when slowing down. Then, the MIL would come on, and I wouldn't have 2nd and 3rd gears until I reset the MIL. I replaced both shift solenoids because they were cheap; no dice. I had the slip code deleted; no dice. It wasn't until I drove with the car in 3rd (until I got on the freeway, at speeds where the tranny wouldn't downshift) that the problem went away. After that, I never had a problem with codes, or the tranny only having 2nd and 3rd gears.
Old Dec 21, 2007 | 06:32 PM
2002t/a06's Avatar
my interceptor scan gauge shows no misfires, but how accurate that is i do not know. thanks for all the input everyone!
Old Dec 21, 2007 | 06:54 PM
Gilbert@Ace Racing's Avatar
If you would like to call and discuss this issue with me tomorrow I will be at the shop.
g
Old Dec 21, 2007 | 07:31 PM
2002t/a06's Avatar
g
sure that would be great. i will give u a call.
thanks
Old Dec 21, 2007 | 11:04 PM
98Camarod's Avatar
Gotta love Gilbert, always willing to lend a hand. If you have hp tuners load the file up and I can compare it to mine.
Old Dec 22, 2007 | 06:58 AM
02 BLK WS6's Avatar
Misfire tables
Old Dec 22, 2007 | 11:24 AM
2002t/a06's Avatar
it does feel like it might be misfiring. we will see when i get back to az.
Old Dec 29, 2007 | 01:54 PM
2002t/a06's Avatar
well i pulled this code with my interceptor scan gauge.
DTC P0757 2-3 Shift Solenoid Valve Performance - No Third or Fourth Gear
not sure exactly whats goin on. most of the time the car is fine but everynow and then it acts up. any more input would be greatly appreciated!
Old Dec 29, 2007 | 11:29 PM
2002t/a06's Avatar
to the damn top!
Old Dec 29, 2007 | 11:40 PM
  #32
performabuilt's Avatar
LS1Tech Sponsor
Common stall code delete the test for the code in tuning it should always be done with any stall over 3000
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Dec 30, 2007 | 12:41 AM
  #33
2002t/a06's Avatar
i deleted the code. a tune is commin soon along with a lot of other things! thanks for all the help!!
