Is my stall blown?
Old Dec 24, 2007 | 10:00 PM
Stang-Slayer's Avatar
Default Is my stall blown?
I figured i just blew out my built tranny a couple months ago and finally got it out....and when i went to tip the Stall upside down to drain it the parts inside slide back and forth....I cant see em i can just feel em...
If so u think it would have blown out my tranny too? There is absolutely no fluid pressure unless revved up and even then its only enough to make the back wheels turn a little when up on jackstands
Old Dec 24, 2007 | 10:58 PM
performabuilt's Avatar
LS1Tech Sponsor
The parts inside the stall will move around when you dont have converter on pump stator, But to really determine wether the converter is ok you would have to fist figure out whats wrong with the trans, What failed? To make that determination.So first things first find out what happened to the trans and inspect the fluild coming out of the converter to see if theres anything in there or not,
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Dec 25, 2007 | 09:21 AM
Gilbert@Ace Racing's Avatar
I disagree.
The only way to know what is going on inside a Torque Converter is to cut it open. Anything else is just guessing. There is no room for failure here. If a converter is compromised and it is installed onto a good working or new unit, then the combination is being set up for failure.
I have converters cut open just to find out the exact question the OP has... every day! A reputable shop will not charge to cut one open, clean it up and give you an estimate. If they do, then you need another converter shop.
g
Old Dec 25, 2007 | 10:10 AM
LS1Tech Sponsor
My intent was that if the converter is relativley new and everythings been working fine and for instance a sprag rolled over, Etc and its a clean failure. Then there would be little point to sending the converter somewhere to have it cut. Its just a matter of making the determination its needed or not. Everyone does not have a converter shop right there like we do who can just cut one open real quick and look.
__________________
Call 888-744-6542
Old Dec 25, 2007 | 08:14 PM
heymoej's Avatar
i agree with gilbert because- how many times do you really want to pull that trans??????? i know if its me, i would like to get it done right the first time, not the second or third have that converter checked & have peace of mind but what do i know we just pulled out the same sponsors built tranny for the 3rd time & now have it getting fixed at another sponsors shop. good luck in your new build & happy holidays to all, my 0.2
Old Dec 30, 2007 | 07:22 PM
heymoej's Avatar
well what did you find out????????
Old Dec 30, 2007 | 10:07 PM
Well I still dont know....The tranny is out of the car and under warantee by a bad *** tranny builder in NC....the only problem is i gotta send it back to him....Itll be a little while i guess....He said he would take a look at the Converter for me too....THe converter was not new with the tranny.....It was bought new and ive put about 10k on it so far....No hard launches so far on my part....
Everything inside slides around allot though when u move it from side to side......I dont remember anything in it moving at all....especially not as much as it does now.....
U can feel its not a bunch of little pieces moving its big solid parts but they sure as hell move around pretty good
Old Dec 31, 2007 | 12:10 AM
heymoej's Avatar
yeah my pt4000 moved on the inside & so did my vig!
Old Dec 31, 2007 | 12:24 AM
yea mines a vig 3500.....damn i dont remember it moving that much though lol
Old Dec 31, 2007 | 09:23 AM
BubaGumpShrimp's Avatar
yes they move around alot inside, what was your original problem
Old Dec 31, 2007 | 12:52 PM
radz282003's Avatar
My SS3800 moved around a lot too. I hope it turns out to be nothing though. Good luck.
Old Jan 1, 2008 | 01:59 AM
Well I have no Trans fluid pressure....Im sure its the tranny pump though....Well im hoping its just that
Old Feb 11, 2008 | 06:49 PM
heymoej's Avatar
well what ever happened??
Old Feb 11, 2008 | 11:05 PM
haha.....Nothing yet.....I drained the tranny and got it in a box ready to ship....just waiting to get some money to do it lol....Ill let u know when i find out man
Old Feb 12, 2008 | 09:34 AM
heymoej's Avatar
cool, good luck!!!!!!!!!
Old Feb 12, 2008 | 05:45 PM
AutomagicLS1's Avatar
My view is if you have ANY sort of trans failure I would never put that converter back in the car untill its checked out
