Can I get some tips on an transgo install?
A couple things to think about when doing it yourself.
Make sure you remember bolt location on the VB. There are 3 8mm one's that need to be correctly placed back in, if they are incorrectly installed you can lock out the transmission.
Think about drilling the transfer plate out to accomodate for a 9.5 in converter if you have future plans for one. The instructions tell you which hole to drill.
A second set of hands is nice when lowering the pan and when installing the VB back. If you are carefull you don't need to grease the check *****.
You will loose atleast 6 qts maybe more with the stock converter, so pick up about 2 gallons, just use some decent dexron III spec stuff.
Delete torque management, or all this work will be futile.
Sombedy who has done it before can probably do it in a couple hours, but I would plan on an afternoon if it's a 1st time.
I fitted the shift kit and int (1-2) and od (3-4) billet servos with a good improvement.
Shifts firm at part throttle from 1-2 but anything over 3500rpms chirps nicely. I only used one shim on the 2nd accumulator so it is the mildest setting from Transgo atm unless it is safe to actually not use a shim at all?
The best thing is the trans keeps the power coming all the way through the shifts but in stock form it would wash away.
Lock up is great because the kit came with a new convertor lock up valve that is an on off type instead of a slipping lock up. The OD servo probably helps alot too.
Here is a link to a DIY guide from Transgo which was a huge help http://www.transgo.com/video.php it is a MP4 zip file so you have to unzip it and then open with a media player from the options list. Worth a look just to see what is inside the 4L60E.
I got a new seperator plate which was handy because the old one was shagged where the checkballs contact it. Also got pinless billet foward accumulator and an alloy oe style with an extended pin runner which were both quite affordable. The oe stuff is plastic and were not sealing very well.
This job isn't too bad as long as you are very familiar with the destructions, the transgo help vid is a godsend too.
Good luck
Vinny
Make sure you lube the crap out of the servo housing when they go back in, it is easy to cut the seals and hard to know until you drive it.
