Car Goes Into Safe Mode When Trying To Stall Help
Old Dec 31, 2007 | 11:47 PM
Garrett114's Avatar
Default Car Goes Into Safe Mode When Trying To Stall Help
I Have A 02 Vette With A Procharger, Rpm Trans, And 2800 Vig Stall. When I Go To Stall Up The Car It Goes Into A Safe Mode At Two Thousand Rpms. Thunder Racing Could Not Figure It Out Anyone Can Help. When It Safe Mode It Dumps Fuel And Pulls The Timing Out.
Old Dec 31, 2007 | 11:50 PM
performabuilt's Avatar
LS1Tech Sponsor
Is it setting any codes when it does this ?
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Dec 31, 2007 | 11:53 PM
Garrett114's Avatar
No The Car Throws No Codes. Its So Bad I Cant Do A Burnout It Just Loads Up
Old Dec 31, 2007 | 11:58 PM
2tone's Avatar
Why do you capitalize every word? lol
Old Jan 1, 2008 | 12:07 AM
Garrett114's Avatar
I leave my cap lock on because for work thats how I have to type everything
Old Jan 1, 2008 | 12:11 AM
LS1Tech Sponsor
I Like Caps Holer At Me Tomorrow I Will Try And Help You
__________________
Call 888-744-6542
Old Jan 1, 2008 | 12:13 AM
Garrett114's Avatar
Thanks I Will
Old Jan 1, 2008 | 07:34 AM
FLT's Avatar
FLT
Sounds like a wiring problem, bad sensor, or a misfire that is causing your issue. That is where I would start. Being that your vehicle is modded anything is possible here. How does it work if you do not stall it up? I highly doubt that this is a transmission issue but I have been wrong before. Vince
Old Jan 1, 2008 | 08:50 AM
Garrett114's Avatar
I have a tech 2 and it shows everything is okay. The car runs great as long as I dont stall it past two thousand rpms.
Old Jan 1, 2008 | 10:01 AM
FLT's Avatar
FLT
So if you put it to the floor from a stop, this is what it does?
Old Jan 1, 2008 | 11:44 AM
Gilbert@Ace Racing's Avatar
Is this a new combination? Or a new problem with an old combination? If i is the latter, what was changed prior to the symptoms showing up?
I too doubt that the symptoms you have described are related to a transmission fault.
Can you define the "Safe Mode" you are referring to? And will it do the same thing if you take it to WOT at say 40 mph?
g
Old Jan 1, 2008 | 12:18 PM
Garrett114's Avatar
Yeah it does it just when I am at a stand still trying to stall the car.
Matt D's Avatar
Retired Street Racer
Try this. Pull the car up to the line, do your burnout, and then when you are rolling up to the line, turn the car off and turn it back on. After that, see if it works fine again. Sometimes when I am racing on the street and have to do multiple burnouts, I have to do that. I know quite a few people who do as well. I think it has something to do with the trans getting hot and the car going into limp dick mode. If it ever does it, we just turn it off and turn it back on, and it works just fine.
Old Jan 1, 2008 | 12:21 PM
Garrett114's Avatar
g
The procharger is old but the trans and the stall r new.
Old Jan 1, 2008 | 12:26 PM
Garrett114's Avatar
The bad thing is I cant do a burnout it just loads up
Old Jan 1, 2008 | 12:28 PM
Garrett114's Avatar
g[/QUOTE]
Safe mode with the tech 2 hooked up the car pulls all the timing out after two thousand rpms and dumps a bunch of fuel
Old Jan 1, 2008 | 12:41 PM
Ok... so the Safe Mode is trying to protect the engine. Most likely it is doing this because of an Engine Misfire, Spark Knock / Detonation condition.
What was the reason for the transmission and converter change?
What was the stall of the previous converter?
g
Old Jan 1, 2008 | 01:26 PM
BubaGumpShrimp's Avatar
he is experiencing limp mode and it almost always happens when you get a higher stall put in. As someon else mentioned about turning the car off then on again to get rid of it. You need to turn the code p0757 off and then go and try it. Do a search for that code on here(you will probably see me making posts in just about all of them) and you may have your answer. I know the 1998-2000 sometimes throw a different code, oh and it doesnt have to throw the code to happen. Po1870 or po751 is also a common code on the older cars when a new stall is added. First start with shutting off po757 and see what happens.
Old Jan 1, 2008 | 07:39 PM
Garrett114's Avatar
g
The trans was stock and converter. I changed because I had ten thousand miles of abuse on the stock trans. I also building a motor for the car.
Old Jan 1, 2008 | 07:41 PM
Garrett114's Avatar
I will try this but it was doing this even with the stock setup in the car.
