Which gets the better 60 ft A4 stall vs M6 with same tires/gears/mods etc?
You are picturing it bc it makes sense in your head. I mean all common sense points to this as being the truth. However, going to the track often helps you to learn what is actually happening with your car. I have watched videos of runs I can remember where I was on the stall hard at the line. I could feel the car trying to push.....and on those runs I couldn't hook for ****. That is supposed to be the softest hit to the tires so I thought it would be the best way to launch. On runs I would foot brake to about 1500 rpms, then stab it on green, the car hooked really well. I realized what was happening. By not unloading the rear suspension, it allowed the car to plant the weight in the rear. Imagine taking off and all the weight is thrown rearward, well all the parts of your suspension are fighting against that. Slamming the rear shocks down from ride height is easier then slamming them down from an extended position. Same with the rear springs and unloading on the front shocks.
