TH400/TH350 users
Old Jul 1, 2003 | 09:24 PM
Slow Z28's Avatar
Default TH400/TH350 users
How many are using the adaptor plate, and how many are just bolting it right up to the block? If you are bolting it right up to the block, you are just missing the very top bolt in the bellhousing, correct? but everything else lines up? Thanks
Chris
Old Jul 2, 2003 | 02:02 AM
00 Firehawk's Avatar
Default Re: TH400/TH350 users
I would like to know this info also.
Old Jul 2, 2003 | 11:21 AM
MacGyver's Avatar
I have a TH400 and I just bolted it straight up. And you are correct on the top hole not lining up. So there are 5 bolts instead of 6 and It's still plenty strong.
Will
Old Jul 2, 2003 | 01:16 PM
RyanJ's Avatar
SSU Moderator
JW will make you a bellhousing to bolt up.
Old Jul 2, 2003 | 03:01 PM
JimmyKash's Avatar
chris trust me......just bolt it up. 1 less bolt isn't going to be an issue
Old Jul 2, 2003 | 05:09 PM
Slow Z28's Avatar
thanks jimmy. i wasn't worried at all, just wanted to make sure the info i remembered in my head was correct
Old Jul 2, 2003 | 07:21 PM
iateyourcat's Avatar
Mine bolted right up and is not using the top bolt.
Old Jul 3, 2003 | 01:13 PM
Fast SS on TNT's Avatar
Get some ARP fastners if your worried. Jegs has them for about $50. They can take about anything from what I'm told.
