Trans cooler
Old Jan 28, 2003 | 05:31 PM
Vic's, 02, WS6's Avatar
Default Trans cooler
Vig states no cooler is needed with their 2800 or 3200, does that sound right?
02 Trans AM WS-6 that is used for cruising.
Old Jan 28, 2003 | 06:13 PM
LS1LT1's Avatar
Default Re: Trans cooler
For a car driven only in below 60 degree weather and never raced maybe....I'd get the cooler for sure either way though, even if just a small one.
Old Jan 28, 2003 | 06:21 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
I would put a cooler on even with a stock TC. Cool tranny fluid = good. <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Old Jan 28, 2003 | 06:52 PM
WJ SOM SS's Avatar
Step up for a cooler, Vic. You'll be glad you did. WJ. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Jan 28, 2003 | 07:45 PM
Ragtop 99's Avatar
Obviously you didn't buy a converter for just cruising as there is no benefit at less than about 50% throttle. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
At WOT it will generate more heat, so definitely get a cooler. All high stall cars need them.
