No second gear
Old Jan 22, 2008 | 03:28 PM
1FASTZ28's Avatar
Default No second gear
Well I believe it is time to begin looking for a new tranny, second gear I believe is completely gone. My car shifts straight from first to third and vice versa when cruising. My question is does it pay to get the thing rebuilt or should I look for a new one? I was looking at FLT and they seem to have some really good prices. I have also seen many good comments about that company. Kinda short on money right now so it may be a few months but I am hoping to have it done before the Power Tour this June. So what is everyones advice?
Old Jan 22, 2008 | 04:24 PM
Gilbert@Ace Racing's Avatar
Based on your comments I would suggest that your unit has an issue with the band or band servo. Either way it is semantics... the problem is internal. Is your SES lamp on?
Vince at FLT does build a very nice unit. But, I would be happy to discuss some options you may not be aware of with you!
Good Luck either way.
g
Old Jan 22, 2008 | 04:42 PM
1FASTZ28's Avatar
Yes my SES light is on in the car, it has been on for a while because I have race headers and an ORY so I don't have all O2 sensors. I took the car in to get checked at a local transmission shop before the snow fell here, they checked the tranny for problems and said that it was not throwing any codes. They then told me they could tear it apart for ~$300 and tell me what the problem was. I don't really want to take it there again because since then I have heard many horror stories about their work.
Old Jan 22, 2008 | 05:04 PM
I understand. The reason I was looking for codes was to try and determine if the condition is something that might be relatively minor so to speak... it's a long shot at best.
And I would be skeptical of any Transmission shop that needs to tear down any unit in order to be able to have a discussion about the build. Bottom line is, it is hurt and needs to be reconditioned... they have a very good idea of what needs to happen, make no mistake about it. They know enough about what is going on to give you several options prior to removing it from the car and holding you captive. It is a very old Marketing ploy that gives all of us shop owners a bad name and reputation. I believe in helping people... not screwing people. That sort of tactic is just not necessary.
Your instincts served you well here.
g
Old Jan 22, 2008 | 06:28 PM
performabuilt's Avatar
LS1Tech Sponsor
When you say it shifts 1st to 3rd I have to ask do you have 4th?
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Jan 22, 2008 | 09:58 PM
blackonblack02_Z's Avatar
I had the exact hting happen to me this last week. it will slip into second if you are very easy on it in first then you let off the throttle and directly into third. and if I am taking off normally I have to let off of it in first to get it to shift and then it goes directly to third. The funny thing is that no other gear is slipping not even 4th, not a bit. We are tearing mine down this weekend and goignt to go ahead and build. good luck with it!! hopefully it is something miniscule (spelling??)
Old Jan 22, 2008 | 10:07 PM
ALLMOTOR346CI's Avatar
I have a spare tranny 4l60e with a shift kit 30k on it works fine sittin on the garage floor doubt you wanna get into the whole shipping thing but i figured i'd throw it out there pm me if youre intrested.....Good luck!
Old Jan 22, 2008 | 10:53 PM
LS1Tech Sponsor
Shipping fedex ground is between 75 and 100 dollars average
__________________
Call 888-744-6542
Old Jan 23, 2008 | 09:57 AM
1FASTZ28's Avatar
That is exactly what is going on with mine, I have fourth gear as well it seems that just second is gone. I have been looking as some different transmissions and hope to get rolling on this soon, thanks for the advice. Anyone else fee free to chyme in any help is appreciated.
Old Jan 23, 2008 | 10:20 AM
The importance of having 4th gear is that tells us that the band itself has not failed. So, there is a good chance that you have either a solenoid failure (not likely) or a servo failure, there could also be a problem in the valve body itself.
Hope that helps.
g
Old Jan 23, 2008 | 10:54 AM
1FASTZ28's Avatar
So I am guessing with the modifications I have right now it would probably be just as good and cheaper to find that out and do a rebuild huh. I am kinda new to the whole transmission thing so I apologize for what may be some stupid questions. I want to get this fixed and fixed right so it is ready for the Power Tour and as I said am kinda short on cash right now so getting a new one and then installing it may be a push in that time.
Old Jan 23, 2008 | 01:22 PM
Why don't you give me a call so i can help you better understand your options. i will be here all day today, and deep into the evening.
817-605-3151
g
