help me settle the cooler debate Plus trans update
I can't get one thing out of my head though....Some die hard cooler guys say removing the stock trans cooler in favor of an aftermarket fanned one is what killed my trans. The trans manufacturer also told me that the stock cooler can remove 32 times more heat via water than an air cooled one and that I should have hooked up the air cooled one in series with the stocker. I'm worried that once I get the trans back together if it was an overheat problem that this will happen again. I will get a trans temp gauge to verify. Also,...does anyone know what thread size the stock cooler uses? If I go that route, Id like to get a fitting to connect stock cooler to AN lines.
Please let me know what your opinions on aftermarket alone vs stock + aftermarket. (also have a 180 degree temp activate switch on cooler.)
THANKS!!!!
Your right on the temp gauge though, thats a great idea and I'll be getting one too. I am going with the 4l80e though, not messing with the 4lshitty-e at all. Just not sure if I need the gauge for this Hoss, LOL
I recommend installing your aux. cooler (at least 19,000 gvw or larger) in series after the oem cooler. You could run a very large aux. cooler by it's self or twin aux coolers works well. But if the oem cooler is still functional, by all means use it!
One the other hand,
PERFORMABUILT
will 100% get my business when I can figure out how to sneak the money for a 4l80e out of the wife's joint account without her knowing!!!.....
I have mine set up where they hang off the back side of the front bumper bar, where the washer reservoir used to be. I pulled the reservoir off (and relocated it behind and below the drivers side headlamp,) and removed all the plastic baffling from in front of the condensor/radiator. Removing that stuff allows for a lot more flow around and through the coolers (not to mention the condensor/radiator) and even allows air to be pulled through the holes I cut into the bumper absorber in front of the coolers, where the OEM grille holes are. Doing all this not only helped my tranny temps', but also lowered my coolant temps'. I've been using gauges to verify these changes on my car so I could remain objective.
Then I wired it so the trans cooler fan only runs when the factory electric fans run. (wired to the fan#3 relay)
Mine is on a TH350 and I haven't seen past 170 even on a 100+ degree day. The last trans I had lasted almost 3 years street and strip. But not many street miles.
One the other hand,
PERFORMABUILT
