Auto : Approx. RPM SHOULD it shift?
When (RPM) SHOULD the FIRST shift occur? The second? Thanks.
Is there a problem? when I used to build 700's I would fine tune the shift points using different governor springs and weights.
If you can describe a problem someone can help explain what you need to do to get it to shift right when you want it to.
There is no normal, or typical shift points, maybe straight out of the factory, but they can be custom tuned exactly to where you want them.
