Those with Transgo Shift Kit
Old Jul 13, 2003 | 10:09 AM
Doc's Avatar
Doc
Default Those with Transgo Shift Kit
I am installing a TCI 3000 and am wondering what kind of results you all have gotten from using 2 or 3 washers in the 2nd accumulator? Thanks guys.
Old Jul 13, 2003 | 12:37 PM
Jorday's Avatar
Default Re: Those with Transgo Shift Kit
I use 3 washers in mine. Because my PT4200 is so loose, the 1-2 shift firmness is really not too firm. 3 washers is definitely the way to go with a big converter. With a converter that is not what is considered really big, you could try 2 and see what happens. It's not too hard to pull the accumulator and add the 3rd washer if you want to try it.
Jordan
Old Jul 13, 2003 | 02:28 PM
TA/30th 1002's Avatar
I just stuck a TransGo gold(0.056") in mine. Is that the shim you're using and is it the same dimension?
By adding shims: you lessen the volume of the accumulator, which in turn speeds up the band apply time. So the smaller the accumulator reservoir, the faster the band applies.
... Ron
Old Jul 13, 2003 | 03:09 PM
silverado's Avatar
Go with 3. Its snappy, and it will tip drinks over. 1-2 shift feels completly different, no hesitation at all. Although I'm not sure about e.t.'s I'd say at least a tenth in my case (slow truck)
Old Jul 13, 2003 | 09:31 PM
Doc's Avatar
Doc
... Ron
That is an afirmative on the transgo gold (o.056") I am going with all three. Got the valve body all back together. Exhaust is all out. Plugs are changed to TR55's. Tommorow PPC 1 3/4 headers and TCI 3000 stall go in. PPC "Y" pipe should arrive later in the week, so I won't know the effect of the 3 shims until at least fri, sat. Thanks Ron.
