Trans cooler w/FTRA
thanks
I have my cooler (with FTRA) facing down toward the ground. It doesn't cool well at all in stop-n-go. I'm getting the HiTek one instead because when I get a frontmount intercooler for the turbo I want the tranny cooler out of the way.
I installed it behind the radiator, in front of the fans.
I had the B&M super cooler, but i couldnt find a decent place to mount it.
GO SLIM LINE!
If you guys run into trouble, with extreme heat or with a really high stall, just put a fan on it, and wire it in with the stock cooling fans, so that it comes on when they come on. Problem solved.
There's plenty of airspace above the cooler with the way I have it mounted.
Dope
I moved the horns out of the way and bolted the cooler in place.
